anyone running +25 offset???????
#52
What wheels??? plz post asap
I was just about to order some 17x8 that the manufacture will drill to our stupid 5x110, want to run some hoosier drag radials on them. The measurements I came up with show the 17x8 35mm wheel will stick out 13(1/2") mm past the stock wheel accounting for the difference in wheel width and offset. Then if you run a 245 the tire add a little more depending on the tire. most 245 are about 9" wide. If I do get these ill post a pick too. I will decide by Monday and should have them by next weekend.
#54
Why not just get silver (or gunmetal) Enkei EKM's? They look the same and you won't have to mess with adapters. They have the right offset (+40?) and if you want them to poke a bit, you could always add a 5mm spacer.
#60
people that dont like stance will say dont do it. its my plan to run a 27 lol or a 32 havent decided
and yes noooo way 19 will fit. 18s are a stretch 17 yeah orolly
Last edited by Maupin SS/SC; 01-30-2011 at 03:03 AM. Reason: Automerged Doublepost
#61
why wont 19's fit i still dont get it!!!!! if i had 17's with a 225 50 17 tire and compared them 19's with a 225 35 19 tire the difference would be that there is no difference so whats the problem nobody has explained this to me it just makes no sense that you say a 17 would fit but a 19inch rim with just a smaller profile wont? makes no sense, please EXPLAIN and stop telling me they wont fit THANKS
#63
unless u drop to a 35 with an 8.5 and stuff like anything less than +30 theres no way it will not rub...im rubbing on my intake with 225/40s 18x8 +42 lol thats all you need to know. i wont rub when i move my intake but a 235 would. it depends on so many factors......your ride height. im tucking in the front. your tire stretch can help as well but if you want traction stretching wont help.
so if you go 19s youll have to have a rediculously low pro tire which is bad ride quality. you might as well get an 18x8 +30 and maybe jsut maybe not need body mods to get the tires to not ruin your stuff
#67
Haz l33t wheelz.
Is.
Win.
#70
Why the **** don't you step up and do what is necessary to make your 19's work?
#71
#73
#74
thats what im sayin yeah smaller and not as wide
#75
on the front its 17x8 +35 and with the 19MM adapter its +16 and the rear 17x9 is +21 heres another pic. No tires yet but planning on a 205-45 in the rear and not sure on the front yet.
