Brembo with oem 18's
How thick of a spacer do I need to fit the oem brembos on the oem 18's from a supercharged ss?
i thought somebody stated it was 5mm, but i could be completley wrong... so bump
pretty sure the sssc rims fit without a spacer
the sc rims dont fit without spacers but the ss/na wheels do for some odd reason. dont be cheap and get the spacers with no lug bolts on them tho.
im pretty sure its 5mm
Originally Posted by ericgt79
(Post 5418708)
(Post 5418708)
I think you will still be hub centric with 5mm spacers. It's not that big of a deal. |
^^ get the hub-centric ones for sure.
I believe that 3mm will work, but 5mm just gives a smidge more room. the problem isn't in the whole spoke, the problem is that the spoke from the back is tapered towards the hub, and the taper is in such a way that it ever so slightly interferes wit hthe inside edge of the bremob caliper. I had a 5mm spacer; http://i303.photobucket.com/albums/n.../DSC00164c.jpg |
