Brembo with oem 18's
I think you will still be hub centric with 5mm spacers. It's not that big of a deal.
^^ get the hub-centric ones for sure.
I believe that 3mm will work, but 5mm just gives a smidge more room.
the problem isn't in the whole spoke, the problem is that the spoke from the back is tapered towards the hub, and the taper is in such a way that it ever so slightly interferes wit hthe inside edge of the bremob caliper.
I had a 5mm spacer;
I had a 5mm spacer;
SS_2009_TC
09-11-2015 05:41 PM
