Cobalt SS 17 inch rims
do 225/50R17's fit on the stock 17 inch rims?
thanks |
Cobalt SS 17 inch rims (stock)
the speedo diff will prob be slower than actual speed but will they be ok? safe at least? thanks. |
Originally Posted by marcod13
(Post 5644630)
the speedo diff will prob be slower than actual speed but will they be ok? safe at least? thanks. a 225/50/17 is 25.9" overall diam. yea they'll fit, 225 is the widest (so i've been told) you can fit on the stock 17's However depending on your suspension setup you may have rubbing issues with 225/50's. i cant say for sure because i cant test it, perhaps someone else can or has already and can chime in. I personally was going to go with 225/45's seeing as they were much closer in overall diameter to the 205/50's. But if you dont mind the speedo being off some, then go for it. |
Try this cool tool I just found...Tire Size Calculator - tire & wheel plus sizing
yes, which I posted....in the correct forum. pls note..
moved! |
Originally Posted by munit06SS
(Post 5644674)
the stock 205/50/17 is 25.1" overall diam.
Originally Posted by Erod
(Post 5644755)
moved!
Originally Posted by futuressturbopurchas
(Post 5644724)
lol ok
merged threads
i have 225/45 and they fit great. sidewall is even with the rim face, and it looks great, i think it handles better.
as said 225/50's would sit higher |
