corvette rims
corvette rims
so i got an idea of putting some corvette rims on my car any ideas if these would fit just because of the offset
http://www.corvetteguys.com/c5-chrome-wheel-18x95.html
extremely to wide. i had posted the offsets in another thread last year and its close to if not more than twice the balts offset not to mention the fact that the bolt pattern is 5x4 3/4 where as the balt is a 5x110
so to give a blunt answer hell no they wont fit
even gettin the pattern bored out wouldnt work. you would have to have a custom wheel made with a smaller offset. you would have probably over 6in stickin outta the fenders if you was to use some kinda adapter and spacer with the vette wheels. it just wont happen unless you have the money to get a completely custom set made and that wouldnt be cheap
Lmao. The tires would stick out a good 4 inches from the car. None the less, if you did manage to get the things on you might not ever have to worry about traction ever again. You should consider going to a custom wheel shop and have them make you something that would fit
jcalvin1126
Oct 26, 2015 12:31 AM
DANRICKARD
Oct 1, 2015 12:08 AM
