il pull out the
hey i just met you
and this is crazy
I need my fenders rolled
so call me maybe
no i dont know of any shops, i asked on a local site and really didnt get much of a reply from anyone.
hey i just met you
and this is crazy
so call me maybe
love the new rims!!! that looks amazing. how much were the 18x9.5 each? and how do the sit inthe fender, any rolling needed up front and do they poke a little or sit flush? i am debating between these rims and the ev-5s. i would prefer to do these since i can get them in a 9.5 width, need a lil more traction. lol
If you want to run the same size in the rear then you definitely need to roll & pull the fenders because the rear pokes more than the front. I can't use pics of my rear fitment as an example because I'm running 10.5s and I had to raise up the suspension about an inch for some clearance until I can modify the rear end for camber. Work in progress!
Thanks, appreciate it. I believe the varrstoens are around $950ish for a set of 18's in their standard matte black finish. I'm not 100% positive though because mine are candy blue finish and drilled to 5x110 so they cost more. I'm running 18x9.5 +22 up front with 225/40/18. You need to roll the fenders and pull a little bit unless you want a lot of poke. Even slightly pulled they still poke a bit but fit beautifully imo.
lol
