Not sure how similar the HHR fenders sit compared with the cobalt, but I am also running a 7.5" wide wheel and they are sitting flush at 29mm offset.
You know I'm not sure either about the fenders. My 42mm offset Drag's sit pretty close...but I know the 5mm spacer is not much at all.
Exactly...so would a 5mm spacer even be worth the $40 and time or should I look at changing my hubs out? I think I read somewhere that a 5mm spacer is the largest you could go with without changing the hubs out or installing longer bolts.
Just get some cheap spacers for like $10 haha, its a little noticeable but not much
7.5" wide wheel with 42mm offset is the stock setup. largest spacer you can go with before installing longer studs is 8mm, iirc. i'll double check on it, but you're suppose to be able to get 7 full turns on the lugnuts for safety. you don't have to change out the hubs, these guys are only doing it to give them a better wheel selection.
exactly. it's not my car, so WHO cares? obviously you're caring right now, so settle down and don't get all butthurt.
i know from experience that you can go with an 8mm spacer and still get the proper amount of lugnut turns, i don't recommend it at all tho. heck, i don't recommend the use of spacers or adaptors in general, but i understand that you crazy kids now-a-days need them to get the "stance" you're going for. have fun with it, YOLO homie!
i was a different guy many years ago my friend. but anywho, even tho i don't recommend them, i do understand why they're used and just hope y'all are being safe with these crazy setups. proper torque, fitting, etc.
with that said & done............. more pics, now!!!!!
