Old Oct 11, 2013 | 11:50 PM
  #10301
Marca34's Avatar
Originally Posted by fitz88
im jealous of both of those^^
elohel
Old Oct 12, 2013 | 07:09 AM
  #10302
Ride quality means nothing to me. I got used to no suspension and dont even notice it anymore. Scraping is just the fun part
Old Oct 14, 2013 | 10:21 AM
  #10303
bmxracerchamp12's Avatar
any of you guys running the custom stance coilovers with the 8k/9k spring rate?
Old Oct 14, 2013 | 10:24 AM
  #10304
Kyle09TC's Avatar
i am. they dont go as low as the regular stances coils because there is less spring compression but if you have wide rims or aggressive offset these are the coils to have
Old Oct 14, 2013 | 11:19 AM
  #10305
yeah they would be on my sedan. stock wheels with 235/40's on them until i can afford a wheel setup. but i will probably get a 18x9 wheel with a 245/40 or 35 tire on them. looking for something i can cruise on and will take turns half way decent
Old Oct 14, 2013 | 03:59 PM
  #10306
I have them as well.
Old Oct 14, 2013 | 08:28 PM
  #10307
GoodLuckBro's Avatar
I wanna go lower...
  #10308
I wanna go lower...
Doit
Old Oct 14, 2013 | 10:34 PM
  #10309
How do you guys like them? They get pretty low or no? Or would you guys recommend something else/better for low and a couple track days a year
Old Oct 15, 2013 | 03:06 AM
  #10310
Doit
How? My Stance's are as low as I can get them and I'm on 17's.
Old Oct 15, 2013 | 10:42 AM
  #10311
Kyle09TC's Avatar
Start cutting S#!T !!!
Old Oct 15, 2013 | 01:03 PM
  #10312
Hmm, very good ideaaaa.
Old Oct 15, 2013 | 02:25 PM
  #10313
as in car is limiting you or the struts are?
Old Oct 15, 2013 | 03:40 PM
  #10314
shorter springs dude
Old Oct 15, 2013 | 03:48 PM
  #10315
Marca34's Avatar
I made my stance go low.
Old Oct 15, 2013 | 03:49 PM
  #10316
get thrifty
Old Oct 15, 2013 | 07:26 PM
  #10317
Marca34's Avatar
[IMG=http://imageshack.com/a/img853/8357/441s.jpg][/IMG]Uploaded with ImageShack.com
Took the ring from the rear and swapped it with the one up front. 4mm lower.
Old Oct 15, 2013 | 09:33 PM
  #10318
Kyle09TC's Avatar
Now that is creativity!
Old Oct 15, 2013 | 11:57 PM
  #10319
Marca34's Avatar
This is as low as it can go without the shock hitting the axle boot.
23 3/4in. fender to ground. It maybe shorter because my fenders are pulled.
Old Oct 16, 2013 | 12:02 AM
  #10320
rcd18's Avatar
off subject, but if i go with a 5x114.3 hub swap would rpf1's clear the front lnf brembos? or does it depend on the off set?
Old Oct 16, 2013 | 12:07 AM
  #10321
Marca34's Avatar
Depends on the offset. a 18x9 +35 wouldn't clear. You would still need 10-15mm spacer.
Old Oct 16, 2013 | 12:12 AM
  #10322
rcd18's Avatar
i was trying to avoid a spacer, but 10-15mm shouldnt be to big, i just wasnt my lugs threating on to as much stud as possible. id have to really look into it because i do want a stanced look but not to aggressive, i was thinking 18x9.5 but i think that might be pushing it
Old Oct 16, 2013 | 12:13 AM
  #10323
rcd18's Avatar
nt03 were on my mind as well, wonder if those have problems clearing
Old Oct 16, 2013 | 12:17 AM
  #10324
You are gonna need extended studs for any spacer bigger than 5mm.
Old Oct 16, 2013 | 10:20 AM
  #10325
Kyle09TC's Avatar
yeah a 10-15mm definitely is big. look into extended lug nuts and you may be able to avoid it but still not very safe.
