What color are those rims I wanna get that color on my cobalt thanks
I need help I'm trying to run wider wheels but the offset thing is killing me I'm looking at 17x9 et20 on a Los lowered 2 maybe 2.5 rear will that work or no I'm not opposed to. Tire stretch but fender roll or pull is out of the question
I'm just trying to get a beefy stance if I run a 215/45/17 it should look pretty good that should be enough stretch to tuck the tire but if you are talking like a inch poke then that prob won't work I've got a slight rub on the R/R when I hit a good bump so I don't want it to hit the rim
Here is the link to a site I found http://www.willtheyfit.com/index.php?width=225&aspect=45&diameter=18&wheelwid th=8.0&offset=40&width2=215&aspect2=45&diameter2=1 7&wheelwidth2=9.0&offset2=20#content
If someone could take a look at this a tell me what you think
Soooo what offset can be used I know a 9 inch wheel is pretty wide for a cobalt so I'm sure there has to be some type offset to pull the cylinder away from the atrut and shock what are you recommending I'd like a tad bit of poke I just think it looks cool
