Old Dec 7, 2011 | 10:17 AM
  #1401
BLAZIN07SS's Avatar
I'm too JDM for you
Originally Posted by RKRamos
So what about 18X9.5 with a +45 offset.
will not clear the coilover with that high of an offset
Old Dec 7, 2011 | 10:18 AM
  #1402
user 70823082's Avatar
damn, didn't even think about the coilovers. Spacers would help in that situation right?
Old Dec 7, 2011 | 05:33 PM
  #1403
EXsoccer1921's Avatar
spacer would work great. just make sure its hub and wheel centric. helps a lot.
thats lsj's stock offset, but like mention it depends on the size of the rim, but for 18x8 it wouldnt clear without a spacer of some sort
stock lsj is +42
Old Dec 7, 2011 | 05:35 PM
  #1404
an 18x8 +45 will net you a 6.3" backspacing. so the wheel will sit .6" further in than a stock sc wheel. i don't know what the offset of the tc is, still 42? i know its a 7.5" wide
Old Dec 7, 2011 | 06:09 PM
  #1405
IdreamofYenko's Avatar
LNF stock wheel offset is +42 and it's 7.5 wide.
Old Dec 7, 2011 | 07:07 PM
  #1406
okay. so that would only bring the wheel in .4" instead of .6"
Old Dec 7, 2011 | 07:35 PM
  #1407
08ssedan's Avatar
What about me?
Old Dec 7, 2011 | 08:38 PM
  #1408
dandaman15's Avatar
Powells PF01's are the same specs, and hes running FE5 and pedders on an ION. He said he didnt rub in the thread he posted... Coils should give even more room. Unless the ION and Cobalt are that drastically different. It will be close though, but it should work. I would still get 5mm spacers to be safe.
Old Dec 7, 2011 | 11:45 PM
  #1409
matt638's Avatar
Originally Posted by 08ssedan
What about me?
not a cobalt.. go away!!
looking good though man
Old Dec 7, 2011 | 11:54 PM
  #1410
08ssedan's Avatar
Old Dec 8, 2011 | 12:31 AM
  #1411
seeyaass's Avatar
Okay I got 2 questions for you guys.
1, I did the Evo mod, keep or take off?
2, what wheels are these? Do they come in our bolt pattern?
Old Dec 8, 2011 | 12:39 AM
  #1412
TommyP's Avatar
AWD > FWD
Those wheels looks like XXR 527s
Old Dec 8, 2011 | 12:46 AM
  #1413
cole3883's Avatar
question for you guys. at what offset would the tc wheels sit flush or close to flush? i think i read that +35 is flush so i was thinking about doing 5mm spacers in the front and 8mm in the back with extended studs. am i in the right track or no? im not going for anything crazy i just want to get away from the train effect. any help is appreciated thanks guys
Old Dec 8, 2011 | 01:47 AM
  #1414
Whining-devil's Avatar
my wheels are 18x8 with 30mm offset and the rears sit pretty flush, so id say u would need an offset of like +27 for the tc wheels to sit flush cause they are 7.5" wide.
Old Dec 8, 2011 | 02:06 AM
  #1415
seeyaass's Avatar
Anybody ever put these on a cobalt??
Old Dec 8, 2011 | 09:58 AM
  #1416
pykie's Avatar
heres my car's quest for aggressive stance.
so far:
Stance GR+ Coilovers 2nd yr rocking them
Enkei PF01 17x7.5 4x100 +38 offset
gotta get the car lower, wider rims, bigger offset, proper tires, and skid plate, already smashed one oil pan.
also gotta adjust the camber so the tires are straight up and down, i go a 3-5degrees camber in the front from my Enkei ZR-2 18x8.5 +42 offset wheels so they wouldnt hit
Old Dec 8, 2011 | 01:48 PM
  #1417
Fitz88's Avatar
is ur intercooler crooked?
Old Dec 8, 2011 | 01:49 PM
  #1418
Whoa! I just noticed that too?!?!
Old Dec 8, 2011 | 01:56 PM
  #1419
seeyaass's Avatar
Anyone ever put xxr 527's on a SS before?
Old Dec 8, 2011 | 01:57 PM
  #1420
Fitz88's Avatar
pretty sure thats what Jookycola is putting on his base model..
Old Dec 8, 2011 | 02:03 PM
  #1421
royce777's Avatar
no the intercooler is straight the car is crooked:p
Old Dec 8, 2011 | 03:09 PM
  #1422
seeyaass's Avatar
Really? You have to get them custom drilled?
Old Dec 8, 2011 | 03:42 PM
  #1423
znew's Avatar
not in 4x100^^
Old Dec 8, 2011 | 03:47 PM
  #1424
seeyaass's Avatar
I was looking at their website they don't come in 5x110... So I'd have to get them custom drilled right?
Old Dec 8, 2011 | 06:02 PM
  #1425
Fitz88's Avatar
yea you probly would, thats why its easier for a base model
