what do you mean, couldn't we just switch out the spring rate in the rears like swap? but id deff be in blazon
i could find another perch to work with the new spring but i should be able to make a new locking ring that will center the spring. basically all i would be doing is making a locking ring for the perch that has the correct measurements for the internal diameter of the new spring and a centering ring to locate the spring on the top. the springs i am seeing in the heights we need would be linear, the progressive springs that they offer are too long. i will be doing this testing in the next month or so. i'll be sure to keep you all informed of how it turns out and drives
Battle of the Delta's 3, cruise and walkaround - YouTube
because this video is just so awesome :p
SKETCHYCREW-ROLLINSKETCHY
Like slobaltss mentioned we were planning on having Swift make us a 7k spring, to replace the hsd/stance 4k spring. but that would probly cost us close to 200$ for 2 springs, so your method would be alot cheaper.
Looks great though! She's cute.
Could these be used with any coilover setup? And would they help me get lower in the rear? I'm not low enough and I don't really wanna buy a whole new setup if I can just replace the rear springs. lol
