CSS Style aggressive fitment thread! Part 2
Old Feb 25, 2011 | 10:40 AM
  #376
JHans5774's Avatar
Wow looks good!
Old Feb 25, 2011 | 11:02 AM
  #377
BLAZIN07SS's Avatar
I'm too JDM for you
can't wait to see it even lower and fix your headlight leak
Old Feb 25, 2011 | 11:21 AM
  #378
Maupin SS/SC's Avatar
my retros completely fogged twice. never happened again?!?!?!
Old Feb 25, 2011 | 11:28 AM
  #379
mofofernando's Avatar
his bottom locator tab probably isnt in its place cause its poking up a little bit. thats how my driver side looks and im too lazy to fix it.
wheels look good and its gonna look even better when you have all the final tweaks done
Old Feb 25, 2011 | 11:52 AM
  #380
Spooled's Avatar
Thanks for the comments guys yea the headlights are pissing me off iv taken them apart and sealed them again a million times and they still leak cheap ass ebay headlights. i have the stock ones i was planning on putting back on and eventually just get retros.
Old Feb 25, 2011 | 12:13 PM
  #381
color match looks good on our color
Old Feb 25, 2011 | 12:17 PM
  #382
Spooled's Avatar
Pic doesnt work
Old Feb 25, 2011 | 01:27 PM
  #383
DOMDOTCOM's Avatar
MADE STANCE COOL
lookin good spooled. i really like how its sitting.
i want my damn adapters!
Old Feb 25, 2011 | 01:32 PM
  #384
Spooled's Avatar
^ Thanks cant wait to see how yours will be, i just need to find someone that can take some legit pics once i get all dialed in.
Old Feb 25, 2011 | 01:38 PM
  #385
DOMDOTCOM's Avatar
MADE STANCE COOL
come to cali hahaha
Old Feb 25, 2011 | 02:33 PM
  #386
Spooled's Avatar
Yea i wish i could
Old Feb 25, 2011 | 03:10 PM
  #387
Jookycola's Avatar
Heres a shitty garage pic the coils are not spun down and wheels are only on this side so not very leveled will have them all on Sunday and be lowered more then take pics.
Fantastic Spooled. Looks great. So this is with what sized adapters then?
Old Feb 25, 2011 | 04:01 PM
  #388
joeyjetta46's Avatar
the wheels are looking good spooled. what mm are the adaptors in the rear?
Old Feb 25, 2011 | 04:02 PM
  #389
boost_junkie16's Avatar
19mm all the way around
Old Feb 25, 2011 | 04:06 PM
  #390
Jookycola's Avatar
19mm without extended studs?
Wow.
Old Feb 25, 2011 | 04:24 PM
  #391
Wow.
They aren't spacers, they're adapters. The adapters themselves have studs in them too. The adapter goes over your factory studs and then you tighten them on. Then you're wheel goes on the studs that are in the adapter and you tighten them on.
EDIT: They look like this.
Old Feb 25, 2011 | 04:47 PM
  #392
JGoodman07SC's Avatar
cant wait to get my adapters
Old Feb 25, 2011 | 05:21 PM
  #393
1LowLS's Avatar
Whats the biggest spacer you can run on factory studs.I have 5mm going on the back(which im not worried about)but the front ,due to camber,the top of the tire is about an inch from the fender lip so,I guess my real question is how big of a spacer/adapter shold I run to make it "flush" with the fender.Note I am not running retarded camber or on a stretched tire.Just want the tire to be flush with the fender lip.All help is appreciated
Old Feb 25, 2011 | 05:29 PM
  #394
Spooled's Avatar
what size wheels and offset do you have?
Old Feb 25, 2011 | 05:47 PM
  #395
Jookycola's Avatar
Um, dude? Spacers and adapters are the same exact thing. Some have studs, some are not thick enough to need them. It's like calling coke soda or pop...it's still coke.
WPN-R x HELLAFLUSH Wheelspacer Kit - 20mm
Do these look at all like the picture you posted? Those are clearly marked as "spacers", These are actually 20mm ones similar in size to what Spooled has. And is the same exact thing as what you posted chief.
Old Feb 25, 2011 | 06:19 PM
  #396
They are close, but not quite the same His are adapters. They ADAPT his bolt pattern from 5x110 to 5x114.3. Spacers just push the wheels out. There is absolutely no reason to run extended studs with a 19mm adapter, if anything it would be nice to run shorter studs so you wouldn't have to shave them down if your wheels didn't have dimples in the back.
Old Feb 25, 2011 | 07:00 PM
  #397
Jookycola's Avatar
Well now, that's different.
Old Feb 25, 2011 | 07:57 PM
  #398
1LowLS's Avatar
There 17's and I'm not sure of the offset.I got em off a Focus if that helps.If I were to guess I'd say 40 but I'm not sure what so ever.The rear is already close so 5mm will put it where I want it,but the front is a inch inside the fender lip from negative camber.
Old Feb 25, 2011 | 10:46 PM
  #399
Spooled's Avatar
^ do you know the width
Old Feb 26, 2011 | 03:02 AM
  #400
Pic doesnt work
its cause this stupid ass site censors my name in posts
