CSS Style aggressive fitment thread! Part 2
Old Aug 24, 2011 | 11:18 PM
  #4026
DOMDOTCOM's Avatar
MADE STANCE COOL
much better. FLY ME TO CANADA SO I CAN SHOOT YOUR CAR!
Old Aug 24, 2011 | 11:42 PM
  #4027
MikeyB's Avatar
fly yourself and ill build you a website :p
what did you change? and what makes it better? just your personal opinion and expeiance? or is it cause i did something wrong?
i know nothing about photogrpahy as you know. so the more learning the btter
Old Aug 24, 2011 | 11:43 PM
  #4028
TommyP's Avatar
AWD > FWD
lightning + your car in the pic = I'm jelly. I can never find the right conditions to take that pic
Old Aug 24, 2011 | 11:45 PM
  #4029
1LSJ2NV's Avatar
Cobalt Nation
that pic is ****
Old Aug 25, 2011 | 01:25 AM
  #4030
G_Pelly's Avatar
How do you not rub in the back going over bumps?
Old Aug 25, 2011 | 01:33 AM
  #4031
dandaman15's Avatar
Coilovers set stiff, and I would still bet he probably does. Needs to get them rolled a bit.
Old Aug 25, 2011 | 01:42 AM
  #4032
MikeyB's Avatar
Coilovers wont go stiff enough, he won't tuck with a roll and a pull either it will still rub he will near rear camber for it to fit properly
Old Aug 25, 2011 | 02:03 AM
  #4033
DOMDOTCOM's Avatar
MADE STANCE COOL
It was the white balance, and the the overall color of the picture. If you look at the original its really yellowish, orangish. I lightened it up a bit, changed the "tone" of it to a cooler color and defined it a bit and lightened it up. Its experience man, every picture you will take need to be edited in some way. Nothing wrong, just the white balance was off.
Old Aug 25, 2011 | 12:01 PM
  #4034
yec0o3e2d's Avatar
Are those grids on Blazin07ss?
Old Aug 25, 2011 | 12:16 PM
  #4035
Menace Kustoms's Avatar
VarrsToens ES 2.2.0 in full polish.
Old Aug 25, 2011 | 02:29 PM
  #4036
sloobaltss's Avatar
Josh. Wheels looks awesome. And damn you Mikey pic looks wicked. I had the perfect spot to take pics last night but I don't have my dslr yet
Old Aug 25, 2011 | 03:18 PM
  #4037
BumbleBee's Avatar
Do you ever carry around a white card or piece of paper? lately with the night shots i've been taking it's helped out a lot. AWB is far off a lot of times.
Old Aug 25, 2011 | 03:30 PM
  #4038
DOMDOTCOM's Avatar
MADE STANCE COOL
That's actually a good idea. I usually just fiddle around with the white balance until I see it's correct
Old Aug 25, 2011 | 05:33 PM
  #4039
G_Pelly's Avatar
Do you guys think I can fit a 20mm adapter on front its a plus 42 offset with a 225/40/18, there is a 5mm spacer on here now so ot would be out another 15mm, I think i can but what do.I know
Old Aug 25, 2011 | 05:48 PM
  #4040
BLAZIN07SS's Avatar
I'm too JDM for you
Old Aug 25, 2011 | 06:21 PM
  #4041
09sscalicobalt's Avatar
can u or should u? 18x8 will never be aggresive flush maybe but not aggresive
Old Aug 25, 2011 | 06:35 PM
  #4042
matt638's Avatar
yum
Old Aug 25, 2011 | 07:11 PM
  #4043
MikeyB's Avatar
You can make an 8 push out as far as you want. But because its a small wheel it will look stupid on the inside. Don't bother with pf01.
Get aggressive wheels and be done
Old Aug 25, 2011 | 11:02 PM
  #4044
G_Pelly's Avatar
I know I can't stretch the tire and look aggressive but I would like to be as flush as possible
Old Aug 26, 2011 | 12:23 AM
  #4045
MikeyB's Avatar
with a tire that size go to +35 max and you shouldn't rub. only a little in the rear. my pf01 on a 225 at +40 rubed bad in the rear
Old Aug 26, 2011 | 01:52 AM
  #4046
G_Pelly's Avatar
I got 5mm spacers all around and the back looks pretty good, so what's that +37 all around and it hasn't rubbed yet
When I had my 245/40s on I had the 5mm spacer in the front I didn't rub, at all and I didn't have one in the rear and it did rub over big bumps
So I know I can go more in the front, but I'm probably not as low as you were, I'm on h&r springs
Old Aug 26, 2011 | 02:07 AM
  #4047
HB_SS/TC's Avatar
I agree just get more aggressive wheels
Old Aug 26, 2011 | 03:42 AM
  #4048
DOMDOTCOM's Avatar
MADE STANCE COOL
Old Aug 26, 2011 | 11:03 AM
  #4049
MikeyB's Avatar
Yeah wait till you lower the car properly. Front is quite forgiving. rear is not that's why my standard set up rubbed. If I had a roll and pull then I would be fine but it's only recently been done
And Dom sweet pic!!
Old Aug 26, 2011 | 12:26 PM
  #4050
G_Pelly's Avatar
Damn I can't afford coilovers right now, I have them on my cavalier, but I rather use that kinda money to make my Car faster
