CSS Style aggressive fitment thread! Part 2
no, you're increasing the preload. The car won't settle when you put it back on the ground.
Adjust those two lock rings so that there is just a SLIGHT tension on the spring. Enough so that when the strut is out of the car, it isn't easy to spin the spring around by hand. Then take off that bottom lock ring, and spin the knuckle sleeve all the way up, and put it back in the car. You'll need an alignment.
it doesnt matter if you order wheels that wont fit lol......if 18x9.5 fits and you dont have to run a huge spacer with the car way up in the air thatd be badass and ill order my vette rims asap... i dont see 9.5 fitting whatsoever......18x8+35 is flush in the rear lol. someone has them and im sure everyone has seen mikes car lol talk about ******* rear camber -_____-
its deserved.....when you might actually have more money than brains its straight retarded to order **** without reading around....only one person has 9.5 on the rear maybe richard does too actually so 2. doms 18x9 +24 sticks out like crazy and would look fine with a big stretch but just ordering randomly is dumb....
