getting new tires...help please
Old Mar 10, 2009 | 10:43 PM
restonSS's Avatar
ok, so i've settled on the nitto nt555 high performance summer tires b/c of their great bang for the buck; I was going to go with kdw 2's again but was told to check these out. my question is on a stock ss/sc 18 inch rim could i fit a 245/45/18 tire on there or is it too wide? Im on stock suspension and was also wondering if that size tire fit the rim would i rub either? again im on stock ride height with stock 18 inch ss/sc rims. If these dont fit would a 235/45/18 fit? im just looking for as much DD traction as possible. thanks.
Old Mar 10, 2009 | 10:46 PM
JJAD's Avatar
they will work on the rim for sure
but they may rub, not to sure!
Old Mar 10, 2009 | 10:47 PM
restonSS's Avatar
ok thanks...bump for rub on a stock suspension setup?
Old Mar 10, 2009 | 10:49 PM
Bika's Avatar
Fail Less.
too wide and too tall for both the car and the rim. they will rub and they may not seat properly on the wheel. go with a 40 sidewall, not 45.
fyi 235/40/18 = closest to stock diameter.
Old Mar 10, 2009 | 10:51 PM
JJAD's Avatar
agreed with the rolling diameter thing, but they will seat on the rim
if your looking for traction try some
michelin pilot sport 2's (PS2)
Old Mar 10, 2009 | 10:52 PM
restonSS's Avatar
the stock tires are 215/45/18. so why wouldnt i go with a 45 sidewall...thats stock.
Old Mar 10, 2009 | 10:56 PM
JJAD's Avatar
because the sidewall of '45' is a percentage of the width, 45%
so because your going wider, if you stick with the same percentage you will have a larger diameter,
so to offset this you do a wider tire, with a lower profile percentage, that way you keep the same diameter and your spedo stays calibrated
Old Mar 10, 2009 | 11:03 PM
restonSS's Avatar
ohhh ok thanks dude. so a 245/40/18 wont fit then? ughhhhhh
Old Mar 10, 2009 | 11:05 PM
JJAD's Avatar
i would guess not, but i'm not to sure, if you went to a 245 you should prob go down to a 35 profile, IF it will even have clearance for turning
Old Mar 10, 2009 | 11:06 PM
restonSS's Avatar
yeah, ok thanks. i think ill just go with a 235/40/18 then. thanks
Old Mar 10, 2009 | 11:08 PM
WhiteSSBalt's Avatar
Not a Sebring
You coming to the big meet in April man?
Old Mar 10, 2009 | 11:11 PM
JJAD's Avatar
good luck!
Old Mar 11, 2009 | 08:56 AM
restonSS's Avatar
depends...i go to school at virginia tech. if the meet is on a weekend i could go home and meet up with you guys. let me know, pm me or something
