How do you remove scratches?
Old Jun 14, 2006 | 10:43 AM
BlkSS4dr's Avatar
I have the high polished wheels and they have fine scratches on them anyone have any advise on how to get them out..???
Thanks
Old Jun 14, 2006 | 11:25 AM
BlkSS4dr's Avatar
noboby has any idea...Bump bump
Old Jun 14, 2006 | 09:15 PM
BlkSS4dr's Avatar
thanks.....
Old Jun 14, 2006 | 09:22 PM
importkiller's Avatar
try mothers chrome polish!
Old Jun 14, 2006 | 10:20 PM
d_backer1's Avatar
Try using some 3M rubbing compound and hand rub the scratches. Next wax them. Should clean up well If you want try using a buffer, but use caution because you can burn the clear coat. Good luck
Old Jun 15, 2006 | 08:27 AM
BlkSS4dr's Avatar
ok now that better...lol....thanks guys
Old Jun 15, 2006 | 08:40 AM
DWK5150's Avatar
Use the finest polishing compund you can get and run in a straight line dont use a circular motion then use a good quality sealant. Mequiars makes a good sealant as does Klasse
Old Jun 22, 2006 | 05:56 PM
VagrantRadio's Avatar
Mothers or Meguiars chrome polish will work just fine and go in straight lines not circles.
Old Jun 22, 2006 | 06:01 PM
distillion's Avatar
good info, what bout for the 18s though?
Old Jun 23, 2006 | 10:59 PM
Mothers and Meguiars make a couple different aluminum polishes also. Try this stuff.
Old Jun 24, 2006 | 02:15 AM
silverSS's Avatar
i used a SOS pad on my SS/SC gunmetal rims...IM a *******...
but yeah now i have a bunch of little scratches in them, not really a big deal, but id like to clean them up, should i try that mothers alum polish or rubbing compound??
Old Jun 24, 2006 | 02:22 AM
artawesome's Avatar
have you or anybody used mothers? i thought about buying it . i havent seen anything from meguiar though.
Old Jun 24, 2006 | 02:32 AM
silverSS's Avatar
is it going to remove the fine scratches, i dont see it doing that, i could see rubbing compund maybe working.....
Old Jun 25, 2006 | 12:03 PM
oldsskool's Avatar
I have a couple scratches on front passenger rim on my 18s... still trying to figure out what to use as they are a painted rim that appear to be clearcoated... so Im very hesitant to use any type of polish on the rim...
Old Jun 25, 2006 | 12:58 PM
I wouldn't recommend using anything close to a steel wool pad on any rims! I work at a parts store and we carry just about everything that Mothers and Megiuars makes, and I have tried just about everything out on my cars over the last few years.
Chrome & Aluminum polish is just a very fine cut rubbing compound with some wax thrown in. It will remove fine as well as large scratches with some added rubbing.
If you have painted rims with clear coat, you might want to get some touch-up paint to match and build up coats by applying layer after layer of touch-up, wet sand it with some 2000 grit wet sand paper until smooth, spray it with some clear coat in a spray can, let it dry and then wax the hell out of it.
Old Mar 3, 2007 | 01:24 AM
UltraCSS's Avatar
For anyone checking this thread in the future, on the Mother's forum they recommend their plastic polish as our rims have a urethane clearcoat on them and not the metal polish...
Old Mar 3, 2007 | 02:13 PM
Coors's Avatar
Question: Does this work for the SS/NA Polished rims?
Maybe we need a step by step how-to
Old Mar 17, 2007 | 01:24 AM
UltraCSS's Avatar
Yes any clearcoated rim...I used the powerball and some Meguiar's "Scratch X" and it did the trick but I want to try the Mother's polish as it was made to use w/ the powerball...Sorry for the wait in the response...
Sorry I meant to say "PlastX" in my last post not "Scratch X", sorry for the misinformation...
Old Mar 17, 2007 | 09:53 AM
BlilBT's Avatar
A Simple Sewn Cloth wheel & Some Polish if the Clearcoat is gone! Then a Loose Cloth wheel with Polish! If it is in the Clearcoat Merquires scratch remover works very well! As stated earlier using Polish for bare Metal will not work if it is Clearcoated!
Old Mar 19, 2007 | 10:05 PM
BlkSS4dr's Avatar
Thanks guys
brickloaf
Show & Shine
56
Jun 18, 2019 12:51 PM
dieGone
Sep 23, 2015 10:20 AM
katahdin_lubricants
Sep 20, 2015 07:24 PM
Snail_SS
Sep 11, 2015 01:02 PM
Getaway_Driver
Sep 8, 2015 09:41 AM
