jacking up the cobalt
i have a base cobalt and was wondering if anyone had pictures of where I can jack up the rear and front of the car and place jack stands? I tried jacking up the car with a floor jack at the points where the spare tire jack would go but those lips just bent. Please help.
so i can use those locations for the front and rear of the car? Can i place the jack and jack stands anywhere up and down from that point as long as i'm jacking it up on that rail?
sorry to keep bugging you man... but i just want to make sure.. so this is wear you first jacked up car up then placed a jack stand where the jack orginially was? As long as i am lifting at the sub frame does it matter specifically at what part front and back i'm lifting at?
i jacked the car up right next to where the jack stand is and then i slide the jackstand under there... as long as you use the sub frame as your jack point you will be ok.... and you need a real floor jack not that POS jack that came with the car
has anyone jacked there cobalt up by these jack points? Is it safe?
https://www.cobaltss.net/forums/show...hlight=jacking
Cptnslo
Sep 24, 2015 09:32 AM
katahdin_lubricants
Sep 20, 2015 07:24 PM
QuickSilver_SS
Sep 17, 2015 05:38 PM
