My SS/SC rims project
when i first got them
sanded and cleaned
1st coat of primer
2nd coat of primer(heavier)
wet sand
1st coat of gloss black paint(light)
2nd coat of gloss black paint(light)
3rd coat of gloss black paint, then dry sand with very fine grit
this is the pic after 5 coats of semi-gloss black enamal paint
still in progress, im waiting for the black enamal to dry then next is a suprise
sanded and cleaned
1st coat of primer
wet sand
you will see
You aren't going heavy enough if you have 5 coats on and still have bare spots. Light coats are good, but too light will leave a "pebbly" finish. You need to put enough on so it can flow out smooth.
I'm doing this same project this week thanks to 4 flat tires that I am forced to replace. Anyway I have all my supplys ie: Dupli Color black wheel coating, Dupli Color clear coat, 1000 and 1400 grit wet/dry sandpaper and tape. I was told that I did not need to use a primer when using the Wheel Coating, is this true? Has anyone on the site ever used it before?
you guys are doing wayyyyy to much work this is all you really need
1.scotch bright pad and scuff the rims up
2.put on 2 good coats of a good primer
3.lay on a decent not to think coat of black
4.put about 4 more layers on and let dry
iv painted i **** you not 18 dif sets of rims
put em on your car so i can see what it looks like i have been wanting to do this forever
