Need higher mileage tires
Old Jun 27, 2012 | 01:05 PM
sponge14's Avatar
I drive about 17k mostly highway miles a year and I need new tires. I had Nitto Neogens that lasted almost 2 years now, but it doesn't look like they make the same ones anymore so I'm having to find some new tires. I like to stick with the bigger brand names. Price is also an issue, I need to stay around 600 - 700 for the tires. Any suggestions?
Old Jul 3, 2012 | 05:10 PM
SSean's Avatar
You may need an alignment. Your toe alignment setting is probably not set right. Go to a couple of different tire shops and have them give you a print out. They usually do a print out for free. On my 2009 ss the rear toe was out .3 degrees on the right passenger rear from the factory. 0.3 is quite a bit for one tire to be out of spec. The rear will need shims behind the hub or they will have to shift the whole axle. Shims are easier.
Old Jul 3, 2012 | 05:20 PM
Omnigear's Avatar
555 nittos
Old Jul 5, 2012 | 06:10 PM
bratboy90's Avatar
Smaller rims usually end up with tires that are like 65k warrantied.
Old Jul 5, 2012 | 07:07 PM
SSean's Avatar
Continental procontact have treadwear of 500 vs. stock 280.
Old Jul 6, 2012 | 06:51 PM
doc@tirerack's Avatar
Supporting Vendor
The Conti ProContact has a 60K mile warranty, and most people get around 50K assuming regular rotation / proper alignment / etc. Its a fairly passive (non performance oriented), so handling might be a little disappointing compared to the stock tires. You could also look at Cont's Extreme Contact DWS (50K mile warranty) or Pirellu PZero Nero AS (45K mile warranty) for better handling, but we'd expect around 40K life span from those.
Old Jul 9, 2012 | 12:55 AM
sponge14's Avatar
Awesome thanks for the suggestions everyone! It would seem the DWS has been the recommendation of most people who put some higher miles on their tires... I don't know how different they are now, but I had some Pirelli's on my Focus and they didn't last for crap (and we all know how much of a performer the Focus is!!!) So I am a little weary on the Pirelli's...
Old Jul 9, 2012 | 08:24 PM
sponge14's Avatar
Will the DWS in a 245/40/18 fit without rubbing on a stock setup? Otherwise I have to drop back down to a 225 from the 235 I am at now....
Old Jul 9, 2012 | 08:35 PM
BlackLsCoupe's Avatar
i get about 3 years out of my BFG's. but i dont think i drive as much as you. and i have winter tires.
bigdeertz
Nov 17, 2016 09:41 AM
RaginChopsuey
Oct 27, 2015 01:27 PM
patooyee
Oct 15, 2015 05:11 PM
Jimmy Beilfuss
Oct 5, 2015 04:18 AM
DANRICKARD
Oct 1, 2015 12:08 AM
