Quick Stock Tire Q
Old May 17, 2007 | 12:47 AM
R&C_rallySS's Avatar
Quick Stock Tire Q
I tried to search for my answer with no provail. Going to fall asleep on my chair soon, was hoping someone could tell me the stock tire size on the Cobalt SS/SC. I'm getting new wheels and tires and I need to figure out what size tires I need to get to keep the speedo the same. Thanks guys....
I would normally just walk outside and look at my tires. My car is currently at my parents house in the garage so I can't.
Old May 17, 2007 | 12:49 AM
Jesse_Chouinard's Avatar
SS/SC = 215-45-r18
I just put on 235/40zr18 and it's supposed to equal out to the same ride height
Old May 17, 2007 | 12:52 AM
Originally Posted by Jesse_Chouinard
SS/SC = 215-45-r18
Thank you very much. +rep for quick reply
Looks like I'll be going with a 235/35/19
The circumference of the P215/45 x 18 original tire is 80.4816 inches
The circumference of the P235/35 x 19 aftermarket tire is 80.0363 inches
Your speedometer reading is 100.% of your true speed.
The ratio of your old vs. new tires is 1.00.
The current differential ratio is:
To retain the same overall gear ratio, you will need a differential with a 0 ratio.
Without correction, your speedometer error will be:
Indicated speed: 10 mph. Actual Speed: 9.94 mph.
Indicated speed: 15 mph. Actual Speed: 14.9 mph.
Indicated speed: 20 mph. Actual Speed: 19.8 mph.
Indicated speed: 25 mph. Actual Speed: 24.8 mph.
Indicated speed: 30 mph. Actual Speed: 29.8 mph.
Indicated speed: 35 mph. Actual Speed: 34.8 mph.
Indicated speed: 40 mph. Actual Speed: 39.7 mph.
Indicated speed: 45 mph. Actual Speed: 44.7 mph.
Indicated speed: 50 mph. Actual Speed: 49.7 mph.
Indicated speed: 55 mph. Actual Speed: 54.6 mph.
Indicated speed: 60 mph. Actual Speed: 59.6 mph.
Indicated speed: 65 mph. Actual Speed: 64.6 mph.
Indicated speed: 70 mph. Actual Speed: 69.6 mph.
Indicated speed: 75 mph. Actual Speed: 74.5 mph.
Indicated speed: 80 mph. Actual Speed: 79.5 mph.
Indicated speed: 85 mph. Actual Speed: 84.5 mph.
Indicated speed: 90 mph. Actual Speed: 89.5 mph.
Indicated speed: 95 mph. Actual Speed: 94.4 mph.
Indicated speed: 100 mph. Actual Speed: 99.4 mph.
^ Close enough.
a 245/35/19 would be the best for the speedo though. Not sure if it will fit correctly.
Old May 17, 2007 | 01:13 AM
can't help you out on this one but good luck!! Let me know if the 245's end up fitting on the stock rim!!
Old May 17, 2007 | 02:11 PM
^ Not sure if there was a misunderstanding. I'm getting new wheels. 19x8.5 I'm going to try and fit a 235/35/19 on it, but a 245 would be best for the speedo. It would end up being like .1 mph off.
Old May 17, 2007 | 02:16 PM
an0malous's Avatar
245 would definately rub i think....
Im pretty sure 235s even have a little rubbing.
Old May 17, 2007 | 08:21 PM
Remedy One runs 235/35/19s with no issues.
Old May 18, 2007 | 05:28 AM
Wink
I don't have any rubbing issues!! i've got the falken's 235/40/18
Old May 18, 2007 | 08:29 AM
Coblasts's Avatar
I thought I heard some where,think the dealer.That more than 3% dia difference causes problems with your ABS due to programed wheel speed for the speed sensors,
Bigger means spinning slower for speed of driving.
Somthing to look into.
bigdeertz
Nov 17, 2016 09:41 AM
RaginChopsuey
Oct 27, 2015 01:27 PM
patooyee
Oct 15, 2015 05:11 PM
Jimmy Beilfuss
Oct 5, 2015 04:18 AM
DANRICKARD
Oct 1, 2015 12:08 AM
