recommended tire size
Old 01-18-2006, 12:16 PM
hardtocope's Avatar
Why does every site recommend a 215/40/18 tire for 18" wheels for a cobalt? Then they recommend a 225/45/18 tire for a 18" wheel on the cobalt ss? It just doesn't make sense!
Old 01-18-2006, 12:24 PM
OniMirage's Avatar
err?
Old 01-18-2006, 12:29 PM
South Central *********
JapEatr's Avatar
i would say best comprimise would be 225/40/18
if for all out traction/street go with a 235/40/18
anything else is really not necessary
and the stock tire size is pathetic
Old 01-18-2006, 12:31 PM
pclear9061's Avatar
im running on 225/45/17 on my RL and they are great ....... just make sure that with the 235's that you dont rub that would suck. but you should be able to run a max size at 235 .... 245 will most likely rub.
Old 01-18-2006, 12:34 PM
hardtocope's Avatar
i'm just going to stick with the 225/40/18 tire
Old 01-18-2006, 02:18 PM
Brandon97Z's Avatar
non/sc's stock size is worse 205/50/17
Old 01-18-2006, 08:29 PM
JapEatr's Avatar
thats a pretty common size tho
you can get that nearly any tire chain
Old 01-19-2006, 08:30 PM
scotty1979's Avatar
Why
Why is it necessary to have such a large rim size? For looks? I am only looking for a 215/40/16 but I have to change out a few parts because the ls only comes with 4 lugz and the rims I want (Konig-Sideways) are 5 lugz. Can a chevy dealership change this hub out for me?
Old 01-19-2006, 08:35 PM
alleycat58's Avatar
I don't know why they would recommend a 225/45-R18 for the SS when that's not the OEM size.
What sites are you looking at?
Old 01-19-2006, 08:37 PM
alleycat58's Avatar
Do not complain about your common lug pattern, my friend. You do not know the pain in the ass of trying to find rims for an almost non-existant lug pattern (5x110).
I don't know why they wouldn't have Konigs in the 4x100 pattern, if I'm not mistaken that's also the bolt pattern on most Civics...would seem to me it should be fairly common.
Old 01-19-2006, 09:17 PM
hardtocope's Avatar
tirerack.com is where i recieved that information.
Old 01-19-2006, 09:26 PM
p7x
p7x's Avatar
ok.....215/40/18 no one should be reccomending that size not close to original at all.
215/45/18 is not a very common size there are only a few manufactures that make that size of tire.
225/40/18 is a very common size of tire that is why its reccomended because everyones makes that size tire but acceptable rim wdiths are 7.5-9. keeping in mine stock is a 7 inch rim.
225/45/18 is close to the orginal diameter a little wider and lil larger while retaining acceptable rim width of 7-8.5. IMO bigger is better.
235/40/18 is the closest to original but creates issues of rubbing and pushes the rim width to 8-9.5
Old 01-19-2006, 09:50 PM
scotty1979's Avatar
Ok I am extremely sorry to ask this but what the hell are these numbers? the first number, the width? the second? the third aint it the rim size? I am real sorry to be ruing this post, but I thought I knew what most of the numbers were but now I am very doubtful. This is for the above post numbers...
Old 01-19-2006, 09:53 PM
p7x
p7x's Avatar
here ya go man
http://www.1010tires.com/tech.asp?type=tires#sizing
Old 01-19-2006, 10:00 PM
scotty1979's Avatar
thank you
Old 01-29-2006, 12:19 AM
M-Dub's Avatar
225/40/18 here... no rub problems at all!
Old 02-06-2006, 07:25 PM
tdirlmeier's Avatar
Ok, so I am purchasing these wheels http://www.wheelmax.com/product.asp?ProdID=1677 as soon as I get my tax return back. My question is what would be the best fitment on a Cobalt LS for tire size? The site recommends 215/40/18 but I want to know what you guys think before I get them. I don't plan on buying lowering springs for my car in the near future if that helps at all. Sorry to jack the thread but I didn't think it was worth a new post.
Old 03-13-2006, 10:31 PM
mrewing65's Avatar
Cool Stock Rims+Wider Tires
I am going to bead blast my stock 18's and paint them gloss black. I need to know what is the widest tire I can use on the stock rim w/o rubbing?
Old 03-13-2006, 10:54 PM
3fo893013L's Avatar
I'm running 225/45/R18 on my SS. Nitto NT 555's. No rubbing and an excellent overall tire for the money. Mine only cost $135 a tire, the Pirellis run at about $250+ a tire. When your all done your spending almost $1200 to have them mounted, balanced with no warranty. Mine was $675 out the door.
There is one gentleman that is running 235/45/R18 but was slightly rubbing. I believe a tire this size is not a good idea overall IMO because your leaving yourself at risk of hiiting a bump and the tire hitting the inside fender wall causing a screw up.
Old 03-14-2006, 02:47 AM
IonNinja's Avatar
1) the SS/SC comes stock with 18" wheels, and yes some people like their wheels to look nice
2) you are crazy if you are going to be switching out to a 5 lug pattern, if you can't find anything in 4x100 that you like then you are one picky bastard. we have probably the most popular bolt pattern there is. and no I don't think a dealership would do something like that. that would have to be one of your own personal projects.
3)215/40/16 sounds like a pretty rubberband type tire...is that smaller than your stock wheel size?
Old 03-19-2006, 10:26 AM
mrewing65's Avatar
I am looking at 225/40/18 for my SS stock rims. Does anyone have any experience with this tire size and the stock rim? I have gone to a site and looked up how much it will throw off my speedo (@ 60 mph indicated I will be going 61 mph). My real question here is will it fit w/o damage on the stock rim or is the rim to narrow?
Old 03-21-2011, 09:47 PM
M.K. SS's Avatar
will i have any issues running a 235/40/18 and slammed on coilovers?
Old 03-21-2011, 10:27 PM
SSean's Avatar
In a word NO. I think people run 245s without problems on 8" wide rims. The question is how wide are your wheels? It is not recommended to put 235 width tire on a 7" wide rim. If you want to be happy for about 10 minutes go for it. You will realize that 235 on the stock 18x7 is a terrible idea because it will bulge. A 225/45-18 would work better if you have the 18x7 SC wheels. If you have 18x8 then you should be fine because that is what the 235 width tire is made for. Don't forget to get a wheel alignment after lowering. I think coilovers are a waste of time as well. You should just get a nice set of lowering springs and get it aligned and call it good.
Old 03-25-2011, 11:01 PM
M.K. SS's Avatar
just put on my tires 235/40/18 on my stock 18in ss wheels and i must admit it was a PITA to put on but they look good. no buldge at all! time to slam it and post some pics!
Old 03-25-2011, 11:20 PM
ronn's Avatar
Weird...they should mount very easily on 7.5" rims... almost like 225/40s. You're saying you had to *pinch* em on? Do you have TC rims, or are they SC and 7" wide? I would not put a 235 on a 7" wide rim.
Quick Reply: recommended tire size
