rim and tire question
The size of the wheel isn't the issue. The overall diameter of your tires are what you want to keep close to the stock size unless you get the new tire size entered in your ECU. If you have an LS, your stock tires are pretty small and leave a huge wheel gap. I would try to find a wheel you like and then find the appropriate sized tire that has a diameter of 25"-25.5". Here is a handy tool to help you compare your stock tire size to low profile tires. http://www.rims-n-tires.com/rt_specs.jsp
If you're too lazy to do some research (lol), I would recommend an 18"x7.5" or 8" wide wheel with 225/40/18 tires. They have a 25.1" OD.
Last edited by Bumpin Balt; Jun 4, 2009 at 07:03 PM. Reason: Automerged Doublepost
DANRICKARD
Oct 1, 2015 12:08 AM
