staggered wheels
#51
To the OP, if you're looking for the exact wheels that are on the silver cobalt posted earlier, they are Rennen RC2's. According to the thread below, it may be able to clear your brakes with a spacer. There is a vendor in there that says they have access to the Rennen brand. It is an old thread though.
https://www.cobaltss.net/forums/whee...ed-fit-150034/
#56
To the OP... The issues you have to overcome for what you are looking to do are finding the correct bolt pattern for the set up that you want and also knowing the offset that will suit you best. 19 staggered will look great on the car(and yes some people dont mind sacrificing a little performance for looks)
The wheels that Remedy has/had on his car were custom drilled, What i would suggest is to check and see if he still checks the site... Email him and ask what offset he was running on the front and back and go from there... You can try to find wheels for the car after that buy either finding another model vehicle with the same bolt pattern that is rear wheel drive and search for wheels under that car or to contact some wheel distributers to see if any of them can get custom drilled wheels for you..
SloobaltSS What offset are you running on your setup?
DANRICKARD
10-01-2015 12:08 AM
