stupid flat tire!
Old Mar 28, 2008 | 11:47 AM
G5GT2007's Avatar
stupid flat tire!
i just noticed my car has a flat tire. i looked and i ran over something and its stuck in the tread. can that be patched? also the tires are worn down some and i called the dealer and its 150 for 1 tire. should i just replace all the tires or can i just change one. i just dont want it to look stupid.
Old Mar 28, 2008 | 11:49 AM
JPizzle's Avatar
It's all about what you want...
If they are all worn, then I would replace all....
Old Mar 28, 2008 | 11:58 AM
PinkStripedCobalt's Avatar
Look at these flat tire pictures, this happened two weeks ago the rock went all the way through my tread to my rim, scratched the rim....
Old Mar 28, 2008 | 05:23 PM
G5GT2007's Avatar
holy crap did that make alot of sound when the rock went into the tire?
my dad took the tire off and looked all around it and didnt see anything. i put water all over the tire and couldint see anything so he filled it back up and put it back on the car. he also said i need tires. so im going to look online for tires. anyone got any ideas about brands and sites. also what size tire can i do i want to put a wider tire on the car.
Old Mar 28, 2008 | 05:30 PM
mrsilent13's Avatar
you should get some nitto's 555
i run on 235 40 18
http://www.2dayparts.com/Nitto%20Tires/
Last edited by mrsilent13; Mar 28, 2008 at 05:30 PM. Reason: Automerged Doublepost
Old Mar 28, 2008 | 05:37 PM
GSMiller's Avatar
I got the tip to a powered screwdriver stuck in one of my tires last fall...
And before I knew it was there my tire was nearly flat. I tried patching it but couldn't get it to work so I put some Fix-A-Flat in it and drove it to a shop. Before it sealed the hole the foam spewed out all in my wheel well and on my rear bumper and that **** was hard than hell to remove. I had to spray some Bug & Tar remover on it and let it set for about 15 minutes to get it off.
Old Mar 28, 2008 | 05:40 PM
G5GT2007's Avatar
i run on 235 40 18
those look good but that size wont fit my car i have the 17inch rims. i just want a performance tires good traction and good handal. i dont drive the car in bad weather.
that looks bad haha. i dont know what i hit i no it was wed night at around 11:20 i was on my way home from work and i heard something hit the under side of my car then 2days later i have a flat tire.
Old Mar 28, 2008 | 05:52 PM
04blownion's Avatar
Fix a flat sucks. I hate that. If you have a tire that has a nail or something and you put fix a flat in it you have reduced the chances of getting it fixed.
Old Mar 28, 2008 | 05:55 PM
mrsilent13's Avatar
well u should try that webside i posted....lots of good deals on there....great performance tires from well know brands for aroound 50 a pop
Old Mar 28, 2008 | 06:13 PM
G5GT2007's Avatar
im looking there and at tire rack.com i want to do a 235 on my car or a 225. whats on there now is a 205-70-17 just to fill in the wheel wells better,
Old Mar 29, 2008 | 02:29 PM
tru2nrtt777's Avatar
I am running a 245/45-17, I got Hankook ventus from pepboys for 89 each.
Old Mar 29, 2008 | 02:34 PM
LS6Rally's Avatar
thats as bg as u wanna go on a 7inch rim. im looking inot the Goodyear Egal F1 A/S for 140/each on tirerack.com
Old Mar 29, 2008 | 02:35 PM
I dont have a 7 inch wide rim, mine is an 8.
bigdeertz
Nov 17, 2016 09:41 AM
RaginChopsuey
Oct 27, 2015 01:27 PM
Jimmy Beilfuss
Oct 5, 2015 04:18 AM
DANRICKARD
Oct 1, 2015 12:08 AM
