Thoughts on this Tire/Size
Old Jul 2, 2007 | 12:23 PM
astrocrep's Avatar
Bridgestone Potenza RE960AS Pole Position (Ultra High Performance All-Season)
Stock Rims, No Lowering...
Is that a good tire / size? I want a bit wider then stock... but no rubing and no noticably bulging...
I found this site: http://www.web-cars.com/math/tiresize.html and it says vs. stock, my speedo will be exactly 1 mph to fast at 45mph. (Meaning shows 45mph when I am actually going 44mph)
What do you think?
EDIT : I want to stay will the Best All seasons... to deal with the weather year round in N.J.
Thanks,
Rich
Old Jul 3, 2007 | 12:44 AM
Infernokron's Avatar
You might look into a 225/45/18 instead, I believe that's closer to the stock size. My brother has 225/40's on his SS/SC, they don't buldge too noticeably but at 75 mph his speedo reads about 79...
If you decide to go with the 225/40, another A/S tire too look at if you havn't allready would be the Micheline Pilot Sport A/S. They are pricey, but Michelin makes nice tires. I have no personal experience with either the Michelin or the Bridgestone your looking at though.
Link to the Pilot Sport A/S: Click Me!!!
If you haven't looked into a set of winter tires and summer tires yet, instead of trying to find an all season tire, it's worth at least looking.
Just a quick copy/paste of a comparison between the stock size v.s. the 225/40/18 and 225/45/18
Top is stock
Middle is 225/40/18
Bottom is 225/45/18
Stock Tire - 215/45R18 >Search Tires Tire 1 - 225/40R18 >Search Tires Tire 2 - 225/45R18 >Search Tires
Section Width: 8.46 in 215 mm
Section Width: 8.85 in 225 mm
Rim Diameter: 18 in 457.2 mm
Rim Width Range: 7 - 8 in
Rim Width Range: 7.5 - 9 in
Rim Width Range: 7 - 8.5 in
Overall Diameter: 25.61 in 650.49 mm
Overall Diameter: 25.08 in 637.03 mm
Overall Diameter: 25.97 in 659.63 mm
Sidewall Height: 3.80 in 96.52 mm
Sidewall Height: 3.54 in 89.916 mm
Sidewall Height: 3.98 in 101.09 mm
Radius: 12.80 in 325.12 mm
Radius: 12.54 in 318.51 mm
Radius: 12.98 in 329.69 mm
Circumference: 80.45 in 2043.4 mm
Circumference: 78.79 in 2001.2 mm
Circumference: 81.58 in 2072.1 mm
Revs per Mile: 812.1
Revs per Mile: 829.3
Revs per Mile: 800.9
Actual Speed: 60 mph 100 km/h
Speedometer1: 61.2 mph 102. km/h
Speedometer1: 59.1 mph 98.6 km/h
Speedometer Difference: -
Speedometer Difference: 2.117% too fast
Speedometer Difference: 1.398% too slow
Diameter Difference: -
Diameter Difference: 2.07%
Diameter Difference: -1.39%
DarrenGC
Dec 24, 2021 01:55 PM
Solaris99
28
Mar 15, 2017 01:22 PM
biniecki
Oct 25, 2015 02:23 PM
cw383
Sep 30, 2015 12:41 AM
