tire pressure
I believe recommended preassure is 30 PSI. For tire longevity, that's probably the best. For performance, you can try stepping it up some, say 35 PSI or so. I believe that's what my bro runs in his SS/SC for normal driving, then 40 PSI for Auto-x. You have to understand though that increasing the preassure will most likely wear the tires out prematurely.
Normally, the best thing to go buy is max-10. Meaning the max tire pressure listed on the tire -10%. There is a whole section on it at the Suspension Bible. And Infernokron, it the tires are rated for over 40psi and your running them at 30, they will wear out faster then normal. I think part of the problem with people wearing out the stock tires is running them at too low a psi.
so if the car says 32 psi but i got aftermarket wheels kumho ecsta to be exact on the tire it says max pressure is 50 psi...i should be putting 50 psi on my tires?
thats what the tire is telling you is the absolute peak before it will risk exploding in your face!
P.S. I can't believe I got the recommended PSI wrong in my first post .
yea misunderstood his post thinking he meant that what the tire wall says is the max pressure that that is the max pressure that should be on the tire see where my confusion came in? and also on his post it says max pressure -10 then -10% way different from each other if we went by -10 than my psi would be 40psi if by -10% than it would be 45psi
The rule is called max-10. It means take the max and subtract 10% as a rough starting number. It will handle and give better road feel, plus slightly improved gas mileage. If it is too stiff a ride for you, drop the psi down a couple to about -20%. For a 40psi max cold tire, such as was the most widely used in the 90's, that would put you at 32psi cold. Tires today are rated at higher psi, but car manufacturers never changed their recommendations.
Max tire pressure-should NEVER be used on a passenger car. The max tire pressure is to be used when using the tire to carry its' maximum load carrying capacity. I think the stock tires have around 1400lbs each. Unless your car picked up an extra ton, bad idea.
A tires main function is not traction, it is to hold the air that carries the weight of the vehicle above it. Tires are generally made by tire manufacures to be sold for more than one type of car. That is why the automobile manufacturer will list a specific tire pressure spec for each vehicle, based on vehicle weight and weight distribution.
You may identify if tire pressure wore out a tire by looking at the tread. If the outside shoulders of the tread are worn more, then the pressure was too low. If the inside portion of the tread is worn more or has a up/down uneven wear then it had too much pressure.
It is all about contact surface with the road.
You will get slightly better gas mileage by over inflating a tire because, less tire tread makes contact with the road giving you less rolling resistance. The cost of the premature tire wear will not offset the gasoline cost.
Tire pressure may be managed for specific application, by those who truly understand the nature of the tire and vehicle, and are willing to adjust tire pressure on a daily basis. If you want to just leave them at a set number go with the OE suggestion.
Steve.
Steve.
yeah its more of a straight line thing.
just to give the biggest contact patch, and to allow a little sidewall deflection to stop the tire breaking loose as much.
Ive seen definate results dropping to 24-26psi.
but im sure to go back to 32psi right after my track days.
yeah "airing down" is mostly used by off roaders when they need maxium traction, like for rock crawling, but I wouldn't recommend if you were going to travel over 10 kph, as it will tear the guts out of your sidewalls and probably break the bead.
DANRICKARD
10-01-2015 12:08 AM
