tire pressure question
Old Nov 4, 2006 | 12:22 AM
DPF's Avatar
DPF
hey guys quick question. i know my tires are going to be low on air pressure now that it is getting colder out. how much air should i put in after they have heated up?
Old Nov 4, 2006 | 12:48 AM
joedashow's Avatar
It's not recommended that you add air when the tires are heated up, because the air pressure goes up (obviously). And of course, you never really know how much the pressure has gone up. So it's best to check and fill your tires before you go anywhere.
Old Nov 4, 2006 | 12:53 AM
DPF's Avatar
DPF
thats what i usually do but i have no way of doing that because im down at school.
Old Nov 4, 2006 | 01:05 AM
joedashow's Avatar
Just buy an air compressor. Just about all of them have an air gauge built right in, and they're relatively cheap.
Old Nov 4, 2006 | 08:12 AM
denniss's Avatar
check them cold and figure out how much you need to add, then go wherever you add air at and add that amount. Check them cold again to make sure you are good. You could also overinflate them a little and bleed air out when they are cold.
Dennis
Old Nov 4, 2006 | 12:26 PM
DPF's Avatar
DPF
Dennis
i think ill try that. i have an air compressor back home but im down at school and hour away.
bigdeertz
Nov 17, 2016 09:41 AM
brandon04
Oct 21, 2015 07:04 AM
no_ss
Oct 18, 2015 11:58 PM
Jimmy Beilfuss
Oct 5, 2015 04:18 AM
DANRICKARD
Oct 1, 2015 12:08 AM
