Tpms help
Old Dec 1, 2015 | 09:28 PM
allpro666's Avatar
Tpms help
Hey guys installed the winter tires on the ss and tried to relearn the tpms and I can get the front left to chirp but when I go over to passenger front it won't read for some reason. The back passenger reads. Can it be a bad valve stem? The signals don't flash either.
Old Dec 2, 2015 | 09:34 AM
I'm guessing the sensor is dead(battery died) and you would need a new one
Old Dec 3, 2015 | 12:25 PM
allpro666's Avatar
Where is this sensor? Or u talking about the valve stem?
Old Dec 3, 2015 | 12:44 PM
The sensor is inside the tire should be connected the the stem
Old Dec 3, 2015 | 02:23 PM
Kolt's Avatar
Sensor bolts to the inside of the stem with a small torx screw. Sensor is probably dead. If you haven't driven on them do that first for about 20mi or so to try and wake it and try to relearn again, sometimes they don't want to wake up after sitting idle for a long period of time.
Old Dec 3, 2015 | 09:20 PM
allpro666's Avatar
Ahh ok gotcha. Thx guys I just mounted the winter tires on. But I had them on for about a week before I tried setting them. So ya I guess it's the sensor. I'm assuming that's a dealer item. Are they expensive?
Old Dec 3, 2015 | 09:56 PM
Maybe 30 bucks each if much
Old Dec 3, 2015 | 11:31 PM
allpro666's Avatar
Thx guys
Old Dec 4, 2015 | 12:25 AM
YelloEye's Avatar
Tire shop will have these for cheaper than a dealership.
Old Dec 4, 2015 | 09:19 AM
Kolt's Avatar
You can buy them online also. shop around for the best price.
Old Dec 4, 2015 | 09:30 AM
I got mine thru ebay just gotta look around for the part #
Old Dec 4, 2015 | 09:57 AM
allpro666's Avatar
Snail wouldn't they all be the same part number?
Old Dec 4, 2015 | 10:14 AM
If you go to ebay they wouldn't I have some I took off a 2010 ss I'll check the part number for you
Old Dec 15, 2015 | 04:48 PM
doc@tirerack's Avatar
Supporting Vendor
Chevy used a couple different part numbers depending on the model year..... let me know the specific year for your SS and I'll look up the part number
Old Dec 16, 2015 | 11:57 AM
allpro666's Avatar
Thx. Mine is a 2010
Old Dec 16, 2015 | 12:07 PM
ItalianJoe1's Avatar
We use aftermarket ones at work from John Dow, I believe the company is called. They are fairly cheap and work well. I don't know if the battery life is as good as OEM but I've only seen one fail in my 3 years there, and we replace a lot of factory ones.
Old Dec 16, 2015 | 02:53 PM
Pasierbek's Avatar
How would you go about installing one of these sensors?
Old Dec 16, 2015 | 02:57 PM
YelloEye's Avatar
Let me google that for you
Old Jan 29, 2016 | 07:16 PM
gilcont9's Avatar
ebay! lol. should be pretty cheap.
Old Feb 3, 2016 | 07:42 AM
Supporting Vendor
Any updates ?
Wheels and Tires
Feb 3, 2016 07:44 AM
janinexxmariee
Nov 29, 2015 02:58 AM
carid
Nov 27, 2015 08:42 AM
Stick
Nov 23, 2015 09:43 PM
Marcov223
Nov 9, 2015 12:16 PM
