upgraded my 06 SS/SC 18" wheels to 225/40/18
i am giving a review on Nexus n7000 225/40/18
heres a image of the tire
they grip way better then stock
ride is better then stock i live on gravel road
handeling on curves is better
over all way better then stock and the tread seems to be pretty good
these are also a directional tire ive put about 1500 miles on these and they are good over all
HERE ARE THE SPECS FROM THE WEBSITE
4 Wide & Straight Channel Design
Multiple kerf Design - Up Grade Snow Index
Shoulder Design - Up Grade Cornering Stability
Aggressive Type lateral Grooves - Anti Hydroplaning
W & Y - Speed rated
U.T.Q.G. 360AA
this is the website that shows more details
http://www.nexentireusa.com/tire_detail.asp?pid=106
W & Y - Speed rated
U.T.Q.G. 360AA
thinking about putting this size of tire on my car and i have it lowered on sportlines do you think it will rub or not. any help would be appreciated thanks
mine do not rub at all however right now it is rubbing cause i need to fix front bumper a lil bit gm diddnt put back the cover and its pushing the wheel well cover out a little so it rubbs only when tight tight turning like almost max other then that no rubbing at all
