Wheel fitment F.A.Q./Stock wheel F.A.Q./How to get wheels for your Cobalt. READ ME!!!
Old Mar 5, 2006 | 09:01 AM
p7x's Avatar
p7x
Originally Posted by 05_Blue_B10WN_SS
Whats the offset of the stock 18" rims on the SS/SC?
42.........
Old Jun 30, 2006 | 02:55 PM
SS_SC_Cobalt's Avatar
Originally Posted by hardtocope
isn't it bad to have a offset different then factory offset. I heard if change the offset u have a better chance of a lug nut breaking while driving? Also is +45 offset more in the fender than the +38 offset?
+45 is in closer than a +35 which pushes the rim out away from the hub (all this is centerline mounting point speak think of it this way your rim, the middle if you have a +35mm Offset it is 35mm away from centerline, a +45 is 45mm away which sends the rim further in the wheelwell
Pushing rims out past the fenderlip increases your track and sometimes stress on the wheel bearings
Old Jul 2, 2006 | 07:26 AM
Erod's Avatar
Moderator Alumni
Hate trying to explain offset without a picture.
I added one to the first post in the thread.
Old Sep 11, 2006 | 06:14 AM
EmperorJJ1's Avatar
Originally Posted by Erod
Adapters are what I really don't recommend. Spacers, eh, I just feel a lot better with a wheel direct to the hub, simply enough. Let alone stock length studs+spacers+stock or equal length aftermarket lugs. eek.
why dont you recommend adapters? i got some for my 01 camaro a while back so im thinking on getting the adapters so i can actually find a good rim (im majorly picky)
Old Nov 6, 2006 | 07:08 PM
Haith's Avatar
Hey guys,
After a lot fo hassles and more help from this forum than I got from my Stealership, I finally have 16" steel rims and Goodyear Nordic Studded winter tires for my 06 SS 2.4l.
The Stealership where I bought it never could tell me what steel rim to go with. If it wasn't for the info provided in this section, I would have had nothing to go on. Eventually, I found a dealership 3 hours away that sold me steel wheels.
After so many run-arounds with the stealership, I wasn't feeling too confident about fitment so I had them test fitted before I bought the tires. It worked!
The GM part numbers from the steel wheels are 9595769. This is a 7" wide rim.
I did not need new lug nuts. I guess the offset was enough to avoid it.
For the wheels, I bought 205/55/16 Goodyear Nordics (studded).
Tire price at Canadian Tire for tires, stem, balancing, install, studding and taxes (14%) came to $565.00 plus almost $300 for the wheels.
These are a new tire from Goodyear so it will interesting to see how they perform. I've used studded tires on all my vehicles. I've driven sporty cars all through our harshest winters and there is something just innately gratifying about passing a 4x4 on slippery roads, as they struggle on all-season tires. :-)
Special thanks to Erod and Raff for their very useful posts and updating this section.
Old Feb 11, 2007 | 06:14 PM
murzak's Avatar
Here is another site:
http://www.dakota-truck.net/TIRECALC/tirecalc.html
This will let you input most tire sizes to bring up a chart showing difference in tire height for different profiles (20 to 95) ranging from a tire size of 12 to 25 inches. You can then hit compare, under full analysis, to get difference in circumference as well as speedometer/odometer error. You can also calculate rpm and effective gear ratio changes. Hope this is useful.
Old Feb 20, 2007 | 07:30 PM
EmperorJJ1's Avatar
they are 5X110
Old Apr 5, 2007 | 12:33 PM
Erod's Avatar
Moderator Alumni
Originally Posted by irishwolf
I thought they were 5x100 but one rim shop in my area told me that according to their computer the 06 ss is 5x110? I am very confused. Getting different numbers everywhere.
My head hurts.
Please read the first post in this thread.
Old Apr 16, 2007 | 02:58 PM
red2006SS's Avatar
does anyone know what the saab bolt pattern is? i saw a nice set of wheels on a viggen and the guy said he may get rid of them. i even like the stock 5 spoked that come on a viggen. would they match up on a cobalt ss?
Old Jun 4, 2007 | 07:03 PM
moxjake's Avatar
More info for you, the stock LS rims off the "sport" model (16" ones) are 16x6.5". Oh, and you can wedge 225 width tires on them if your tire guy knows what he's doing
Old Jun 8, 2007 | 08:47 PM
  #36
Gravana-FNG's Avatar
Does anyone have any hard data on the 07 Cobalt bolt patterns? I just looked at 3 '07 Cobalt LT's. 2 had 5x110 16" hubcaps/steel wheels and one had 4x100 15" aluminum wheels.
Old Jun 12, 2007 | 03:05 AM
  #37
Brooksy's Avatar
i dont like spacers, adapters or anything like that....i dont like selling them to ANYONE at our shop.
Old Jun 17, 2007 | 03:33 AM
  #38
ridemlow03's Avatar
got a question, well the other night i busted a tire and had to get a new one. well the only size they had that would fit my car was 225/40/18. I couldnt wait for a day or two so i just grabbed it. first post says our rims are 18x7 but the 225/40/18 will only fit on a 7.5-9" wide rim. can anybody explain this and also can i go up to a 235 or 245 series tire on the stock rim and be fine with it and the clearance.
Old Jul 16, 2007 | 11:18 AM
  #39
Joeyavhu's Avatar
How would you figure out the hub diameter in mm for a diffrent rim?
Old Jul 23, 2007 | 09:29 AM
  #40
BlueSS-supercharged's Avatar
Exclamation
Originally Posted by ikeryder13
Will a 18x8 with a 40 offset rim fit a cobalt ss supercharged?
Originally Posted by infernica
So does 18x8 fit on our car ( looking at sky rims to put on, except aftermarket ones ). I believe tis 18x8 at 45+. Just curious, so I don't go out and spend the money and then am unable to use said wheels.
i want to ask the same question, so bump to anwser us 3 please
oh ya
Old Jul 26, 2007 | 03:27 PM
  #41
ikeryder13's Avatar
My 18X7.5 rims hit my front brake... Why is this?
Old Jul 27, 2007 | 02:45 AM
  #42
EmperorJJ1's Avatar
offset... what offset did you get?
Old Aug 3, 2007 | 06:42 PM
  #43
trickybig9er's Avatar
can anybody tell me the maximum size rim that you can have on the 06 ss/sc and tire size
Old Aug 15, 2007 | 11:17 PM
  #44
bobert's Avatar
rims
im thinking about buying a set of motegi dp12 for my 07 ls coupe...they are 18x7.5 with a 45mm offset....will this be ok....i dont want to go get them if i dont need to
Old Aug 30, 2007 | 07:05 PM
  #45
Originally Posted by 7Thirty
anyone know the weight of the stock 16's on an LS?
I don't, but a SS/SC 18" with tire weighs 52-55 lbs. I don't remember which it was before I worked at Gravana and was just helping out on the widebody project.
Old Oct 20, 2007 | 01:09 AM
  #46
Erod's Avatar
Moderator Alumni
Originally Posted by laserbluels
Has anybody tried 19's yet?
mmmm.......
https://www.cobaltss.net/forums/wheels-tires-96/official-19-rims-club-72103/
20"s are fine also of course, with 225/30/20s.
Old Feb 11, 2008 | 06:53 AM
  #47
EmperorJJ1's Avatar
Erod edit: Wheel spacer/adapter info:
either get them drilled, get new hubs, or get a wheel spacer/adapter (http://www.skulte.com/info_pages.php/pages_id/3)
Old Feb 11, 2008 | 12:06 PM
  #48
Erod's Avatar
Moderator Alumni
Alright. Going to lock this and delete random posts. Please post in the w/t forum your specific questions with ACCURATE, COMPLETE SUBJECTS. If you have anything useful and informational for this sticky PM it to me, etc.
Thanks
Solaris99
28
Mar 15, 2017 01:22 PM
Jan 12, 2016 12:01 AM
c_m_shooter
Sep 27, 2015 04:40 PM
