whos running 225/45/18 for ss/sc?
Old Oct 1, 2006 | 09:26 PM
s2kricer17's Avatar
for those who are running 225s, are you guys having and issues with them rubbing your inner fenderwell? i just noticed mine doin that today, esp making a right had turn...
Old Oct 1, 2006 | 10:23 PM
Vaughts05ss's Avatar
I've got nitto 555's 225/45/18 on the front and have no problems at all. They were slightly used when i got them though so I dont know if that'd have anything with it.
Old Oct 1, 2006 | 10:25 PM
carbombss's Avatar
ive got bfg kdw2 225 40 18 an absolutly no issues with em
Old Oct 2, 2006 | 12:54 PM
s2kricer17's Avatar
hmmm... maybe i just need to get some miles on em...
Old Oct 2, 2006 | 01:01 PM
suburbanrobot's Avatar
now that sounds like a great size and tire package!!!!
do you like your KDW's? and does your car have stock suspension?
Asphalt Assault's Avatar
No you need 225/40r18 not 225/45r18's that will be the difference if your truly rubbing. I think it is quite possible your rubbing by the way.
Old Oct 2, 2006 | 01:40 PM
carbombss's Avatar
yup love em an im loweed on h&r springs
Old Oct 2, 2006 | 06:20 PM
s2kricer17's Avatar
that makes sense... but my dad bought em so i cant complain... i guess i can just blame him...
Old Oct 2, 2006 | 06:29 PM
SilverSS/SC's Avatar
I run a 225/45r18 BFG KDW 2 with no issues at all .
Old Oct 2, 2006 | 06:31 PM
kraker's Avatar
^^^^+1
Old Oct 2, 2006 | 09:37 PM
that is good to know.... are you lowered? shouldnt make a difference but would like to know
Old Oct 2, 2006 | 09:51 PM
Badmunky's Avatar
Im runing 235/40/18 KDW2s on 18x7.5 rims and I dont rub.
The stock rim has the wrong back spacing and is to narrow for some 225 tires depending on the brand. Not all 225s are the same contact patch. there the same section width but the contact patch can vary by up to .75"s
You need to find the specs for your tire and compare them to the KDW2s as others are runing that tire with no rubing.
Later
Old Oct 3, 2006 | 01:02 AM
3ds138's Avatar
Im running 225/35/20. Driv 20inch rims on Toyo Proxy's by 7.5 and no rub at all.
Old Oct 3, 2006 | 01:14 AM
BlueSS-supercharged's Avatar
actually i got rub in my kdws esp. during right turns iv asked this when i first got mine on but it seemed to go away not only rubs with im hard braking right turning
but i did have issuse with mine, it really looked like the tire was on the spring.
Old Oct 3, 2006 | 05:16 AM
Im not lowered right now . I will be here in a couple months , but 17's and 245/45r17 tire will be used at that time . I dont think Id have a problem with the 225/45's lowered either , Ive been all over my wheel wells lately measuring for a custom rim . Like Badmunky said though , some 225's are wider than others .
Old Oct 6, 2006 | 04:44 PM
Serpico's Avatar
i think a 45 series tire will be too tall especially if you want to run a 245.....also keep in mind that the correct size wheel width for running a 245 is 8.5 inches unless u want a stretched or bulging looking wheel/tire package either of which will look retarded imo
Old Oct 6, 2006 | 06:56 PM
245's would look great
bought ASA 17x8's for the winter..... I am going to get a set of sticky rubber for those same 17's next spring to do driving events. and keep the 18's for commuting.
do you know of someone who has actually run a 245/45-17.... are they on 8" or 8.5" rims and are they on a different offset ?
heck 235's would look good
thanks...
Old Oct 6, 2006 | 09:10 PM
Serpico's Avatar
thanks...
as a general rule the rim width/tire width are
7"=215
7.5"=225
8"=235
8.5"=245
wider tire on a smaller rim causes buldging, narower tire on wider rim = stretch so for maximum traction and proper tire wear its best to stick to the industry standard
Old Oct 8, 2006 | 02:39 PM
7"=215
7.5"=225
8"=235
8.5"=245
good info...thanks
Zharrington_2010LNF
Feb 8, 2016 01:43 PM
RaginChopsuey
Oct 27, 2015 01:27 PM
brandon04
Oct 21, 2015 07:04 AM
dieGone
Oct 1, 2015 06:27 PM
Extremespeed
Sep 29, 2015 04:34 AM
