Widest 19" tire with sportlines
Old 09-05-2007, 05:09 PM
wallas06SS's Avatar
What's the widest tire I can get for a 19" wheels with my sportlines. I was thinking 225 35. I didn't know if anyone has a 235 on theirs. Any help would be appreciated. THanks in advance.
Old 09-05-2007, 05:16 PM
DrPuttsSS/SC's Avatar
Don't forget that the biggest factor is the wheel offset.
With 38-42mm, on 18s, some guys have no problems with 245s.
Old 09-05-2007, 05:18 PM
wallas06SS's Avatar
These are 40mm offset.
Old 09-05-2007, 05:23 PM
Good, that offset is right in the middle, so your tire should be centered pretty well in the wheelwell.
It depends on the width of your rim too, but I'd guess you should be ok with 235s or so. But I have no personal experience so wait to hear from the guys that are runnin these.
I'm not trying to be vague, it is just that a lot of things affect how wide your tires really are. Different tires from different companies sometimes vary in the cross sectional width, even with the same tread width. And an inch wider wheel will definately move the tires's edge out 1/2" So even if some guy comes on here and says that his 235s fit, you need to know his offset, width, and exact tire or his setup may not work on yours.
Good Luck!
Old 09-05-2007, 05:26 PM
wallas06SS's Avatar
Good Luck!
okay, cool. It's 19 by 8". Thanks!
Old 09-05-2007, 05:33 PM
R&C_rallySS's Avatar
235 should work fine. Ask Remedy, he knows good tire sizes for 19" wheels. Good luck...
Old 09-05-2007, 06:27 PM
wallas06SS's Avatar
Yeah, I was hoping he would chime in.
Old 09-05-2007, 07:20 PM
7Thirty's Avatar
im pretty sure he is running 235's on the back but he has a larger wheel.. he has 19x9.5 if im not mistaken... but 235's would be the largest you could safely go. 245 is gonnna be .3 inches taller as well as being a wider tire.. my scrub some
Old 09-05-2007, 08:02 PM
sick_ss/sc's Avatar
i got 245 no problems
Old 09-05-2007, 08:17 PM
wallas06SS's Avatar
You have 18's. I'm talking about 19's.
Old 09-06-2007, 09:19 AM
wallas06SS's Avatar
Old 09-06-2007, 09:22 AM
Former Cobalt Owner
PlaysWitCars's Avatar
Im running 225/35's on my 19x8's which have like a +35ish offset i believe
Old 09-06-2007, 09:24 AM
wallas06SS's Avatar
How much clearance do you have? You think I could go 235's?
Old 09-06-2007, 09:28 AM
Former Cobalt Owner
clearance from what?? haha the fender.......none
Old 09-06-2007, 09:32 AM
wallas06SS's Avatar
I mean turning clearance without rubbing.
Old 09-06-2007, 10:07 AM
Former Cobalt Owner
I have no turning issues at all unless its a hard turn
I had no issues with rubbing or turning when i had my sportlines on with 19s
bigdeertz
11-17-2016 09:41 AM
01-12-2016 12:01 AM
RaginChopsuey
10-27-2015 01:27 PM
DANRICKARD
10-01-2015 12:08 AM
09-27-2015 08:53 PM
Quick Reply: Widest 19" tire with sportlines
