ZZ Performance ZZ Performance is a proud Supporting Vendor
ZZP - Big brake kit?
Old Oct 12, 2013 | 08:20 PM
  #51
06cobalt racer's Avatar
Originally Posted by sydewayz
Also suggest a slotted rotor only option as some people don't like running drilled due to cracking issues eventually.
or even better a blank rotor
Old Oct 12, 2013 | 08:55 PM
  #52
Dyn0mitemat's Avatar
I'd be seriously interested if it come with pads and a choice of just slotted (preferred) or just blank rotors.
I plan on picking up a set of tc wheels for my lsj, but I assume they wont fit under lsj wheels considering the lnf brembo's dont fit
Old Oct 12, 2013 | 09:32 PM
  #53
colodude18's Avatar
Glad to see I'm not the only one petitioning for blank rotors. Quite honestly, the only place you NEED these is at the track and the drilled ones will crack open like a ripe melon ;-)
Old Oct 13, 2013 | 01:36 PM
  #54
Zooomer's Avatar
Supporting Vendor
Site is updated with choice for solid.
Pads are included.
Old Oct 13, 2013 | 02:24 PM
  #55
slapbetcommissioner's Avatar
[QUOTE=Zooomer;6687322]Caliper will be twin piston aluminum red with wrinkle black bracket.
[IMG]
What caliper is in this picture. Just curious since you Have brembos on your site change of plans?
Also can you post some better pics? The on the store are minuscule?
Old Oct 13, 2013 | 03:28 PM
  #56
colodude18's Avatar
^^and this.
A side by side of the stock Brembo calipers and these would be really cool.
Old Oct 13, 2013 | 03:52 PM
  #57
Powell Race Parts's Avatar
That looks very much like an off shore version of the PBR two piston slider caliper found on C4 Corvettes and last gen Camaro LE5 (?) brake option. It packages easier than a Brembo from a wheel point of view.
I am personally not a fan of sliding calipers, I prefer monobloc, but this route permits ZZP to provide humongous rotor sizes without risking fluid volumes as the caliper has only two pistons not four as found in monobloc Brembo's. And its way cheaper.
Looks like Zoomer is not using his first plan for calipers. Brembo works and it is apparently less money than the LNF upgrade, with new parts.
Old Oct 13, 2013 | 08:03 PM
  #58
colodude18's Avatar
Thanks John! Sent you a PM.
Old Oct 13, 2013 | 08:37 PM
  #59
^^^ got it. replied.
Old Oct 13, 2013 | 09:04 PM
  #60
sydewayz's Avatar
I believe that caliper is what they were originally going to use, now they are using the brembo calipers off of the newest gen Camaro SS
Old Oct 13, 2013 | 10:48 PM
  #61
andrewcarr1993's Avatar
Yeah their definitely using genuine Brembo calipers. Let me quote their webpage.
"Looking for big brake upgrade? Here you are, a 14.5" front brake kit that uses a genuine Brembo 4 piston caliper.
This will fit factory LNF Brembo wheels, but we have not tested fitment on any other wheel."
"(2) 4 piston Brembo calipers w/ hardware
(2) 14.5" rotors
(2) Caliper brackets
(2) Stainless brake lines
(4) Copper washers
(2) Banjo bolts
Pads
Instructions"
Old Oct 15, 2013 | 02:44 PM
  #62
wardak33's Avatar
what i'm wondering is what happens if the parts wear out? pads are easy, just ask local parts store for rear brake pads on a newer camaro ss, but what about the rotor? camaro rotors have a 5x120 bolt pattern and we have a 5x110..
Old Oct 15, 2013 | 02:48 PM
  #63
yellowsupercharged06's Avatar
Guess your going back to ZZP for rotors then,
or do a LNF brembo swap
Old Oct 15, 2013 | 02:51 PM
  #64
northvibe's Avatar
Originally Posted by CordiaDOHC
I know this is typically the story. But my rears are almost gone. Fronts probably 20%?
With me shifting the focus on my camaro( 1/4 mile...) the cobalt also gets it focus shifted (more backroading and handling oriented). Also I do backroad the car fairly often and the stockers are just plain horrible for this (yes I know pads and a fluid flush would fix most of that).
stock what is horrible? Stock brakes are great for track and DD....soooo ?
Old Oct 15, 2013 | 02:55 PM
  #65
northvibe's Avatar
stock lnf brembo's fit with SS/SC wheels when a 5mm spacer is used.
Old Oct 15, 2013 | 03:24 PM
  #66
wardak33's Avatar
Well i have a saab and was looking into getting the LNF brembos, but if i can get these, why not lol the rotors i have right now are 314mm but what i like about the set up i have is that the brake contact surface between the rotor and the pad is all the way from out edge of the rotor to the hat.
Old Oct 17, 2013 | 07:42 PM
  #67
Zooomer's Avatar
Supporting Vendor
That is correct
Old Nov 2, 2013 | 05:55 PM
  #68
Bumpin Balt's Avatar
I would like to pick up this kit, but I would prefer a slotted only rotor option. My current cross drilled rotors are cracked. A Hawk HPS pad option would be nice also. Why were ceramic pads chosen as standard?
I would also like to know if a big brake friendly 17" wheel will clear these?
Old Nov 2, 2013 | 06:01 PM
  #69
It really is annoying that this is so much cheaper than the stock Brembo brakes I upgraded too.
Old Nov 2, 2013 | 08:06 PM
  #70
colodude18's Avatar
Because Hawk HPS suck, defeats the purpose of getting larger rotors...
Is this a serious question? The pictures clearly show that they barely fit inside an 18" wheel...
Make you wonder, doesn't it...
Old Nov 2, 2013 | 08:12 PM
  #71
How would Hawk HPS pads defeat the purpose of getting larger rotors? They bite harder than my stock pads did.
Old Nov 2, 2013 | 10:35 PM
  #72
colodude18's Avatar
Not sure what was "stock" on your car, but compared to the Ferrodo/brembo pads that come stock on the SS/TC, the HPS are a joke. I ran them for a few months and threw them away...
Old Nov 2, 2013 | 11:35 PM
  #73
EmperorJJ1's Avatar
im pretty sure he's an LSJ not an LNF
Old Nov 3, 2013 | 02:47 AM
  #74
Nfamous60's Avatar
i will sell my brembo calipers with R1 Concept Preimum Slotted rotors with new pads barely 300miles and stainless steel lines if anyone is interested. i plan on upgrading to this 475 for everything will make a thread ASAP when i get off work.
Old Nov 3, 2013 | 03:46 AM
  #75
EmperorJJ1's Avatar
did you put them on ur car urself?
