Initial clutch return spring setup. I spend (wasted) an hour or 2 messing with this yesterday, apparently some of the FF cobra guys don't even run them. Some Corvette guys run a tension spring such as this, while most OEM setups seem to cam-over, where they return, but also assist the clutch pedal engaging. I may change this, it is admittedly a half assed solution, but it should be adequate
