2008 Cobalt SS Brembo brakes - Min. 17" Wheels
#52
For those interested, I just contacted the service manager at my dealership. He's going to look into whether or not GM plans to produce winter wheels suitable for the car, and pass up the suggestion if not.
#53
Ahh looking at that photo that's a really close fit. What happens if debris on the road like rocks and junk gets lodged between the wheel and the brake?
I think I'll just put the Bembo stickers on my drum brakes haha!
#54
so i have my LS right....and now i def need some stopping power....can i just slip these onto my existing rotors or do i need to upgrade to your rotors in order for me to even think about using these brembo's
which i know my ls is a 4 lug and your rotors are 5
#56
if you can lock up your wheels right now with your current brakes you don't need any more stopping power, unless perhaps you are road racing or a lot of subsequent high speed stops, neither of which you should be doing in a Cobalt LS
#58
its not just a cobalt ls....its been heavily modded.....faster than any stock ss.....mayb even keeps up with a stage 2...im not sure yet....i have drilled and slotted rotors in the front.....and braided brake lines all around....its stops fairly quick.....but who doesnt want to stop quicker. just in case you really need to.....so your saying it possible but alot of work...i might just have to look into it
#60
lower control arm
knuckle asm
bearing asm
driveshaft
bushing
Basically you would have to change out all but maybe the strut and maybe the driveshaft will still work if the splines on the inside of the bearing assembly are the same. Or you make an adapter plate that goes on the rear of the knuckle assembly that has the caliper mounting bolt holes in the right place.
#61
That doesnt make any sense, on pg. 2 (ecotecbreed?) said that he got 17" from a sport model to fit. How would 18s from an ss NOT fit when 17s do?
#62
1 Post
There is more than just the rotor diameter you need to worry about. The brembo caliper is very wide...and the offset of the rim needs to be relatively high, +45mm, in order for it to clear.
pawntec (10-31-2016)
#64
http://www.gravanatuning.com/1591/38...e_2.0_FWD.html
Im thining of getting the 15mm spacers. I have to check to see what the offset is on the SS/TC rims then subtract the SS/SC rims to find the best spacer. To big and it is dangerous, to small and well you loose ur caliper upon rim rotation. i think the TC rim is +45 and the SC rim is +35 but im not sure. Maybe someone can clarify that.
#65
#69
Brembos
You'd need the SS\TC wheels to fit. Hweel manus are frantically trying to come out with aftermarket wheels for the SS\TC but are having a hard time with it due to those HUGE brembos. Spacers range from 3mm to 20mm then custom. I tried a stock 18" wheel upgrade for my SS\TC and you can not use a deep-dish wheel, the spoke and such need to be on the oputside on the lip\rim and the spokes need to be super thin. I tried several wheels that Discount says fit, No go even with an excessive 20mm spacer, same no with Tire Rack. Patience is the key, as Discount and Tire Rack took full messurments of my frt wheels, brembos and clearances. Plus, the 17" whls from the older pre 2008 SS are 17x7' and the wheels on the new SS\TC are 18x7.5"
#71
I just got a set of BSA Model 264s in 17", with Gizlaved Nordfrost 5 tires (225/45R17). With 3mm spacers on the front they fit fantastic, and they were pretty damn cheap. If anyone in Toronto is looking for a winter tire package, head to Steelcase Tire in Thornhill (Steeles/404 area).
#72
#73
And out of curiosity, what did you pay?
#74
#75
