2008 Cobalt SS Brembo brakes - Min. 17" Wheels
Old Aug 25, 2008 | 10:40 AM
  #51
MapOfTaziFoSho's Avatar
GM is going to have to offer something here...do they intend to just not sell these models in the winter months?
Old Aug 25, 2008 | 02:43 PM
  #52
Force's Avatar
For those interested, I just contacted the service manager at my dealership. He's going to look into whether or not GM plans to produce winter wheels suitable for the car, and pass up the suggestion if not.
Old Aug 26, 2008 | 04:48 AM
  #53
Luminaeus's Avatar
Ahh looking at that photo that's a really close fit. What happens if debris on the road like rocks and junk gets lodged between the wheel and the brake?
I think I'll just put the Bembo stickers on my drum brakes haha!
Old Aug 26, 2008 | 04:55 AM
  #54
mrsilent13's Avatar
so i have my LS right....and now i def need some stopping power....can i just slip these onto my existing rotors or do i need to upgrade to your rotors in order for me to even think about using these brembo's
which i know my ls is a 4 lug and your rotors are 5
Last edited by mrsilent13; Aug 26, 2008 at 04:55 AM. Reason: Automerged Doublepost
Old Aug 26, 2008 | 09:07 AM
  #55
Too much work man...just upgrade to another car.
Old Aug 26, 2008 | 09:21 AM
  #56
krispy's Avatar
yea, thats too much work
if you can lock up your wheels right now with your current brakes you don't need any more stopping power, unless perhaps you are road racing or a lot of subsequent high speed stops, neither of which you should be doing in a Cobalt LS
Old Aug 26, 2008 | 09:32 AM
  #57
Bingo!
Old Aug 26, 2008 | 01:44 PM
  #58
mrsilent13's Avatar
its not just a cobalt ls....its been heavily modded.....faster than any stock ss.....mayb even keeps up with a stage 2...im not sure yet....i have drilled and slotted rotors in the front.....and braided brake lines all around....its stops fairly quick.....but who doesnt want to stop quicker. just in case you really need to.....so your saying it possible but alot of work...i might just have to look into it
Old Aug 26, 2008 | 02:30 PM
  #59
Black08SSTC's Avatar
yea i tried to install my 18" SC wheels and they werent even close. i had another 2threads that were showing between the rotor and the base of the rim. So needless to say a 25mm spacer is the littlest that we can get probably
Old Aug 26, 2008 | 03:01 PM
  #60
krispy's Avatar
well the LNF has different:
lower control arm
knuckle asm
bearing asm
driveshaft
bushing
Basically you would have to change out all but maybe the strut and maybe the driveshaft will still work if the splines on the inside of the bearing assembly are the same. Or you make an adapter plate that goes on the rear of the knuckle assembly that has the caliper mounting bolt holes in the right place.
Old Sep 18, 2008 | 02:17 AM
  #61
Austyn_Balt's Avatar
That doesnt make any sense, on pg. 2 (ecotecbreed?) said that he got 17" from a sport model to fit. How would 18s from an ss NOT fit when 17s do?
Old Sep 18, 2008 | 10:45 AM
  #62
There is more than just the rotor diameter you need to worry about. The brembo caliper is very wide...and the offset of the rim needs to be relatively high, +45mm, in order for it to clear.
Old Sep 19, 2008 | 12:06 AM
  #63
so what do us people in the north do about winter tire? I'm not using my stock rims in the winter and i dont even think they make 18 steelies?
Old Sep 19, 2008 | 07:50 AM
  #64
http://www.gravanatuning.com/1591/38...e_2.0_FWD.html
Im thining of getting the 15mm spacers. I have to check to see what the offset is on the SS/TC rims then subtract the SS/SC rims to find the best spacer. To big and it is dangerous, to small and well you loose ur caliper upon rim rotation. i think the TC rim is +45 and the SC rim is +35 but im not sure. Maybe someone can clarify that.
Old Sep 19, 2008 | 10:02 AM
  #65
TrevMo's Avatar
I think TC rims are 42....it is stamped on the rim...
Old Sep 19, 2008 | 10:03 AM
  #66
I am going to run a spacer and 17" steel wheels. I won't run the spacer in the rear.
Old Sep 19, 2008 | 12:55 PM
  #67
ecotecbreed's Avatar
I will use 17 SS/Sport wheel with 3mm spacer in front, no spacer in rear
Old Sep 19, 2008 | 03:56 PM
  #68
3mm, I don't even know if they make that!
Old Sep 26, 2008 | 01:05 AM
  #69
SportredSS's Avatar
Brembos
You'd need the SS\TC wheels to fit. Hweel manus are frantically trying to come out with aftermarket wheels for the SS\TC but are having a hard time with it due to those HUGE brembos. Spacers range from 3mm to 20mm then custom. I tried a stock 18" wheel upgrade for my SS\TC and you can not use a deep-dish wheel, the spoke and such need to be on the oputside on the lip\rim and the spokes need to be super thin. I tried several wheels that Discount says fit, No go even with an excessive 20mm spacer, same no with Tire Rack. Patience is the key, as Discount and Tire Rack took full messurments of my frt wheels, brembos and clearances. Plus, the 17" whls from the older pre 2008 SS are 17x7' and the wheels on the new SS\TC are 18x7.5"
Originally Posted by G5GT2007
this will fit on a G5 GT they come with 17inch rims. what would i have to do to put these brakes on my G5?
Old Oct 26, 2008 | 09:38 PM
  #70
I got the wheel installed!
3mm shim was installed also
Tires are Pirelli Sottozero!
Old Oct 26, 2008 | 10:43 PM
  #71
Force's Avatar
I just got a set of BSA Model 264s in 17", with Gizlaved Nordfrost 5 tires (225/45R17). With 3mm spacers on the front they fit fantastic, and they were pretty damn cheap. If anyone in Toronto is looking for a winter tire package, head to Steelcase Tire in Thornhill (Steeles/404 area).
Old Oct 26, 2008 | 10:50 PM
  #72
malachii's Avatar
I go the exact same package from the exact same place Confirmed - it works great. The wheels are also hub-centric, so no centering rings are necessary (woo-hoo!)
Old Oct 26, 2008 | 10:53 PM
  #73
Force's Avatar
You weren't on Steelcase road on Saturday, were you? I spotted a Black SS/TC driving into the place across the street.
And out of curiosity, what did you pay?
Old Nov 14, 2008 | 08:28 PM
  #74
ogc's Avatar
ogc
If you dont mind me asking what did you pay?
Old Nov 14, 2008 | 10:00 PM
  #75
malachii's Avatar
I paid $1600 all in, but I heard another member paid a little bit less, but there's some family connection there, so good luck getting that price!
