G85/lsd
There are numerous ways. Easiest way is looking under your trunk liner, on the left side, you will see a sticker with a bunch of codes on it.... Just have to look for "G85" and you're golden.
Another way you can tell is if both your front tires are off the ground (jacked up), spin one tire, if the opposite tire spins the same way, you have an LSD. If it spins the opposite way, you don't. Good luck!
You can also run your vin through this website:
Comprehensive Chevrolet, Saturn, GMC, Hummer, Cadillac, Buick, Oldsmobile, Pontiac, Geo, Dodge, Plymouth, Jeep, Chrysler, Ford, Lincoln, Mercury, Mazda Truck, Mercedes VIN Decoder
And see if your car has the RPO code G85 for the LSD.
bphage
02-02-2011 05:53 PM
