G85/lsd
Old 10-03-2012, 12:02 AM
Derkachenko's Avatar
G85/lsd
How do I find out if I have LSD on my 2010 SS?
Old 10-03-2012, 12:05 AM
Black_Mamba_09's Avatar
Its in the trunk, lift up the carpet and on the driverside there is tag with a bunch of codes
Old 10-03-2012, 12:09 AM
FrankSS/SC's Avatar
There are numerous ways. Easiest way is looking under your trunk liner, on the left side, you will see a sticker with a bunch of codes on it.... Just have to look for "G85" and you're golden.
Another way you can tell is if both your front tires are off the ground (jacked up), spin one tire, if the opposite tire spins the same way, you have an LSD. If it spins the opposite way, you don't. Good luck!
Old 10-03-2012, 12:11 AM
carstedt's Avatar
dump the clutch see if 1 wheel mark or 2
Old 10-03-2012, 12:23 AM
Fastgti69's Avatar
Not always true, I don't have LSD and I've put 2 tire marks down numerous amounts of time.
Old 10-03-2012, 12:29 AM
ItalianJoe1's Avatar
If you can see the label on the top of the trans it also has LSD on it if it has one. The trunk label is the easiest, but only the tire turning is 100% accurate.
Old 10-03-2012, 12:31 AM
soundjunky's Avatar
1) You're canadian; Canadian cars were all "export" RPO 'Z49' cars
2010 'Z49' Cobalt SS = all have LSD
There were no factory options for 2010 Canadian destined SS's;
The only factory option for USA destined 2010 SS's was the LSD.
fair enough?
Old 10-03-2012, 12:35 AM
BLue NoTe's Avatar
...drive it
Old 10-03-2012, 10:44 AM
JBThrasher22's Avatar
You can also run your vin through this website:
Comprehensive Chevrolet, Saturn, GMC, Hummer, Cadillac, Buick, Oldsmobile, Pontiac, Geo, Dodge, Plymouth, Jeep, Chrysler, Ford, Lincoln, Mercury, Mazda Truck, Mercedes VIN Decoder
And see if your car has the RPO code G85 for the LSD.
Old 10-03-2012, 05:02 PM
SSlobalt's Avatar
Old 10-09-2012, 07:29 PM
duramaxdave's Avatar
That what I was going to say lol
LNFwagonSS
09-29-2015 09:04 AM
bphage
02-02-2011 05:53 PM
Quick Reply: G85/lsd
