Bullseye Power Batmowheel for Ko4
Old 11-04-2011, 12:28 PM
  #76
EXsoccer1921's Avatar
Originally Posted by FF_ace
Once there is ten people on the list then we can get this ball rolling
i PM'd you with everything you need.
Old 11-04-2011, 12:35 PM
  #77
elecblue06's Avatar
Originally Posted by Dart_SI
Do they already have a batmowheel for a gt2871r? I think that will fit since the compressor and housing are the same on the bnr.
yea i would be down for this probably .. could be even more dastardly fun lol
Old 11-04-2011, 12:39 PM
  #78
Dart_SI's Avatar
Even if the wheel was the same exact size the design of it allows it to be 6% more efficient. If I wasn't in the field right now id be figuring out how to get a batmowheel for the bnr.
Old 11-04-2011, 12:45 PM
  #79
Boosted4's Avatar
Add me to the list! For $400 ish I'd be more than happy with just an additional 20+whp
Old 11-04-2011, 01:01 PM
  #80
FF_ace's Avatar
Got it turbo will be sent out monday
Old 11-04-2011, 02:13 PM
  #81
MastaShaKe_88's Avatar
i don't think they do dart. gunney and mastashakethatass i added you to the list on the first post.
good ****..
If this things nets 10-20 more whp and is more efficient up top then it's definitely worth it to me, much cheaper than a K04+ also
Question tho.. Aside from the design, what's the real differences between the batmowheel an the double...?
Old 11-04-2011, 02:25 PM
  #82
celblazer's Avatar
I'm interested in this for my HHR SS.
How hard is the turbo to R&R?
I have a down pipe I need to put on anyway so might as well upgrade the turbo while I'm in there.
Old 11-04-2011, 07:04 PM
  #83
Originally Posted by MastaShaKe_88
good ****..
well, the design IS the difference hahah. basically what a batmowheel does with the inducer blades, a double does it on all the blades. gains are slightly more than a double bat. but a turbo this small me and david agreed that testing out a single batmo first would be better to see what the gains are. stepping up to a double afterwards may on yeild another 1-2hp/5ftlbs..
not hard at all. unbold the compressor cover, unbolt the wheel
Old 11-04-2011, 07:35 PM
  #84
celblazer's Avatar
I meant to remove and replace the turbo on the car. I'd just send the turbo to them to install the wheel.
Old 11-04-2011, 07:46 PM
  #85
cdnite's Avatar
If we send in the entire turbo can they machine the compressor side to fit a larger wheel like the K04+ has and then add a Batmowheel?
This would be the best Stock turbo gains we could see. And I'd totally be down!!!!!!
Old 11-04-2011, 07:56 PM
  #86
Hmmm...
Old 11-04-2011, 07:59 PM
  #87
I will ask him about it. but i don't believe they do any porting
Old 11-04-2011, 08:52 PM
  #88
No porting. but installation and balancing of the turbo is free if you send it in.
Old 11-04-2011, 09:31 PM
  #89
corn gas ftw....
ssblackstealth's Avatar
sub'd
Old 11-04-2011, 11:35 PM
  #90
beast10007's Avatar
nice! another MI shop
Old 11-05-2011, 12:16 AM
  #91
dayhoff35's Avatar
hmm interesting and tempting, too bad im back to stock
Old 11-05-2011, 12:41 AM
  #92
Ryan@zzp's Avatar
Bullseye is not an install shop. They don't do any mechanic work.
Old 11-05-2011, 04:57 AM
  #93
Yeah bullseye definitely won't be receiving any of your cars for a build. thats what ZZP is for. but their expertise in turbo applications is one of, if not, the best. and the fact that they're willing to take this step for us and produce a drop in wheel for a platform thats not even made any more is amazing. If gains are shown, ya'll better not make me look like a fool and back out of ordering, its $399!!!! what more could you want.
Old 11-05-2011, 08:24 AM
  #94
vahdyx's Avatar
I have a broken used K04+ would they be able to add a wheel in that and fix the seals... Basically rebuild it. Essentially making it a K04++
Old 11-05-2011, 08:54 AM
  #95
cdnite's Avatar
Yeah A wheel for the K04+ thats what Im talking about!!!
Old 11-05-2011, 09:01 AM
  #96
cdnite's Avatar
Maybe a second list for those with a K04+ that they want to add the Batmowheel... shouldnt be to much to do its only 2.5mm bigger.
Old 11-05-2011, 10:19 AM
  #97
turbohornet88's Avatar
k04 + batmowheel......I like what you guys are thinking!
Old 11-05-2011, 02:23 PM
  #98
jarhead's Avatar
That would be exellent Vahdyx. Could you post a pic of the exhaust side of you're turbo so people can see the difference? The porting that is done I think that may be the difference why the KO4+ had good gains while the 2860 w/o the exhaust side porting did not. I would hate to see this not get the gains and die off like the bnr 2860 did if it was just a matter of the exhaust side porting.
Old 11-05-2011, 03:31 PM
  #99
what exactly is the Ko4+?
Old 11-05-2011, 04:33 PM
  #100
ATLsilverSS's Avatar
a big wheel ko4:
The Home of WERKSracing products!
Quick Reply: Bullseye Power Batmowheel for Ko4
