LNF CEL codes
Nope haven't figured out what's wrong, besides the cel it's running fine. I'm prob going to take it in this week just to make sure nothing serious is wrong with it.
I've been looking for information about the P2096 code. Apparently it's not all that common and isn't a directly sensed code, but rather a code that is calculated.
Here is a thread I found from a 300c forum.
http://www.300cforums.com/forums/srt...e-bueller.html
Below is an excerpt:
"Set Condition:
If the PCM multiplies short term compensation by long term adaptive as well as a purge fuel multiplier and the result is below a certain value for 30 seconds over two trips, a freeze frame is stored, the MIL illuminates and a trouble code is stored. Two Trip Fault. Three good trips to turn off the MIL.
Possible Causes:
EXHAUST LEAK
ENGINE MECHANICAL PROBLEM
1/2 O2 SENSOR
(K141) O2 SENSOR 1/2 SIGNAL CIRCUIT
(K299) O2 1/2 HEATER CONTROL CIRCUIT
(K904) O2 DOWNSTREAM RETURN CIRCUIT
FUEL CONTAMINATION"
Ours may be triggered differently, but it's a start at least.
"Set Condition:
Possible Causes:
EXHAUST LEAK
1/2 O2 SENSOR
FUEL CONTAMINATION"
#36
"Set Condition:
Possible Causes:
EXHAUST LEAK
1/2 O2 SENSOR
FUEL CONTAMINATION"
"Set Condition:
Possible Causes:
EXHAUST LEAK
1/2 O2 SENSOR
FUEL CONTAMINATION"
My car is going into the shop next week for the possible broken lifter or roller. whatever it is that breaks.
thanks
mike
#37
OK, here is my issues... I NLS'd today and missed the gear. i revved high but hit the limiter. after that, my car started misfiring just as it would on a cold NLS. i shut it off, tried restarting it, but no change. sounds like a subaru. popping backfiring and misfiring. i have recently put a catless DP on. I'm getting p0107 code. also there is a lot of liquid in the exhaust, doesn't smell like coolant or gas, but there is a lot of it... whats wrong with my car? i posted this in a few places so....
#38
Try resetting the ECU and sometimes this will bring it back. If it doesn't then you'll need another one. They are about $40, so not a huge deal I suppose.
You might have gone above 22.5psi for longer than a few seconds and your ECU is ignoring the reading thinking that the sensor went bad. Resetting it will make the ECU give the MAP another chance. If the MAP is still inop, your car will either throw another code, continue running funky, or both... and you'll need a new one.
What's basically happening is the car is using your MAF and some guesswork instead to figure out what the car is doing. The MAF doesn't have very fast response so suddenly adding or letting off the throttle will throw it off for a second and possibly cause popping, backfiring, and uneven boost.
#42
Would someone be able to explain how to read this chart properly. Say for example I am completely stock and throw code P0101. How do I read the info from this chart and troubleshoot?
#43
The second column shows you what function it's looking for.
Such as fuel trims exceeded. Then look 2 columns over and it shows you what value is needed to exceed the limit. Such as 20 for fuel trim. This means the car saw a fuel trim +/- 20%
So with P0101 wither your fuel trims are messed up or your MAP/MAF sensors are messed up. This could be due to an intake, air filter, air leak or sensor issue.
That's from my understanding
#44
Ok so P0101 is listed on the first page.
#46
I got a P0301 Cylinder 1 misfire, what could be the cause of this? It's runs fine until I get near 25psi of boost then it knocks and looses all power.
Dealer is acting like they can't get it to do it again.
#47
About a week ago my car felt sluggish and a CEL came up which after scanning was found out to be a P0236. After the computer ID'd it at Autozone the alarm went away. Then, yesterday, my car felt sluggish again and sure enough a CEL came on. Today, however, it felt fine and the light went away this afternoon. I didn't get it checked out this time but I'm sort of assuming that it's the same P0236.
Has anyone had this problem before? I'm about to go check the guide posted and see what it says.
#48
#49
