LNF Specs PDF
LNF Specs PDF
Credit to Hucks1987 for pulling this off a nice site which can't be named because it has an expensive yearly membership. LNF'ers or anyone I suppose, will find this helpful.
papageorgio (12-14-2019)
ENGINE PARTS
Air Filter 25894265 $46.86
Balance Shaft
Balance Shaft
24 - Right 12587215 $109.47
24 - Left 12587216 $109.47
Balance Shaft Bearing
Bearing
Front
Part Of Balance Shaft.
26 - Rear 12581395 $14.41
Balance Shaft Chain
27 - Chain 90537370 $63.73
Balance Shaft Chain Guide
28 - Upper Guide 90537336 $8.26
29 - Lower Guide 90537369 $8.26
31 - Tensioner Guide
Contact dealer for most current part and price information. 90537299 $19.61
Balance Shaft Chain Tensioner
30 - Tensioner 90537300 $66.79
Camshaft
13 - Intake 12589335 $346.73
13 - Exhaust 12589340 $346.73
Camshaft Gear/Sprocket
18 - Camshaft Gear
Includes: Timing Chain, Tensioner And Guide. 24424758 $35.29
Cylinder Head Assembly
1 - Cylinder Head 12622906 $775.00
Cylinder Head Gasket
2 - Head Gasket 12589346 $46.43
Drive Belt
Serpentine Belt
Contact dealer for most current part and price information. 24466973 $28.47
Drive Belt Tensioner
Serpentine Tensioner 24430296 $106.31
Engine Mount
Mount 25877466 $116.31
Trans Mount
Front 25948444 $52.98
Rear 15945572 $55.89
Side 25829028 $132.82
Exhaust Manifold Gasket
Manifold Gasket 12622668 $11.30
Front Crankshaft Seal
16 - Front Cover Seal 12609467 $13.08
Fuel Filter
Fuel Filter
15233471 $83.24
Harmonic Balancer - Crankshaft Pulley
40 - Pulley 90537704 $83.49
Intake Manifold
Intake Manifold 12616667 $348.36
Intake Manifold Gasket
Manifold Gasket 12589366 $10.16
Lifter / Lash Adjuster
11 - Valve Lifters 24100005 $18.12
Oil Cooler
Oil Cooler 12601390 $116.02
Oil Cooler
Oil Pan
41 - Oil Pan 12601240 $192.33
Oil Pressure Sender
Oil Pressure Sending Unit 24577642 $16.34
Oil Pump
42 - Oil Pump
Includes Oil Pump. 12606580 $236.05
Piston
34 - Pistons
Includes One Piston And Pin. 89018108 $100.17
Piston Ring
33 - Piston Rings
Includes: One Standard Ring Set For One Piston. 89018107 $28.46
Rear Crankshaft Main Bearing Seal
39 - Rear Main Seal 12591866 $30.70
Rocker Arm Assembly
12 - Rocker Arms 12565203 $22.51
Timing Chain
19 - Timing Chain 24461834 $129.64
Timing Chain Guide
21 - Upper Guide 12588387 $20.42
23 - Tensioner Guide 24449448 $52.08
22 - Lower Guide 13104978 $19.55
Timing Chain Tensioner
20 - Tensioner 12608580 $53.44
Timing Cover
14 - Front Cover
Timing Cover Gasket
15 - Front Cover Gasket
Contact dealer for most current part and price information. 24435052 $26.48
Valve
5 - Intake Valve 55563529 $21.25
6 - Exhaust Valve 12597371 $37.15
Valve Cover
3 - Valve Cover 12612781 $180.29
Valve Cover Gasket
4 - Valve Cover Gasket 12609291 $30.96
Valve Guide Seal
7 - Valve Seals 90537241 $4.29
Valve Spring Lock
10 - Valve Keeper 90354648 $4.48
Valve Spring Retainer
9 - Valve Spring Retainers 90537243 $5.72
Variable Valve Timing Actuator
Actuator
Intake 12578515 $175.43
Exhaust 12621505 $140.33
Water Pump
7 - Water Pump
Includes Gasket. 12624936 $251.58
Balance Shaft
Balance Shaft
Bearing
Front
Balance Shaft Chain
Camshaft
18 - Camshaft Gear
Drive Belt
Serpentine Belt
Engine Mount
Trans Mount
Fuel Filter
Fuel Filter
15233471 $83.24
Intake Manifold
Oil Cooler
Oil Cooler
Oil Pan
Oil Pressure Sender
Oil Pump
42 - Oil Pump
Piston
34 - Pistons
Piston Ring
33 - Piston Rings
Rocker Arm Assembly
Timing Chain
Timing Chain Guide
Timing Cover
14 - Front Cover
Timing Cover Gasket
Valve
Valve Cover
Valve Cover Gasket
Valve Guide Seal
Valve Spring Lock
Actuator
Water Pump
7 - Water Pump
Enlighten me... Does anyone have working blueprints, locating the dimensions of the engine mounts compared to the engine bay, and dimensions between locations on the engine block?
zeeky420 (04-25-2020)
