2007 LSJ idle issue with AC on
Ok here is what is happening, with AC on the car will surge when coming to a stop, it will recover and idle fine after a few sec. The car will not do this with ac off. The car has been tuned by Zzp a few times bit it still does it. My mods are in my sig. Car runs fine except for this.
Rent me! per hour
There is a few other things that come into play. Who did the fuel injector scaling? You ever clean the throttle body? Have you logged fuel trims?
Not everything is an easy fix.
Zzp did fuel incector pulse, the TB was replaced earlier in the year due to it failed. I only have the issue with AC on. The idle with it off is silky smooth. I have logged the car numerous times and cant see anything out of ordinary
Rent me! per hour
if the scaling is off, the whole tune is off. This is the point i was trying to make. There is some timing table manipulation that can be done as well to take care of it.
