ALERT**Dipstick popping out? Here is solution!
#54
#PIP3983: Oil Leak From Top Of Dipstick - Replace Intake Manifold Gasket - keywords accel acceleration CEL crank crankcase dip engine excessive hard high MIL P0171 pressure repeat SES stick WOT - (Nov 16, 2006)
05 AND 06 COBALT 04 -06 REDLINES
they should swap it for you if it is still under warranty.
#58
guys, does anyone here know how to remove the oil dib stick along with the bracket, without having to bend anything? see, mines broke on the braket where it bolts to the intake manifold, therefore is lose and ive been having issues with oil coming out from the end of the tube, when car is in motion. i try looking for some info in how to take those out but didnt have much luck. any help would be really apreciated.
thanks!
thanks!
#60
Just my 0.02
#61
just fixing my 2007 cobalt from this problem it was a cracked piston. Thought it was just the rings till i opened it up. I was running about 19 to 20psi of boost so im fixing it and turning down the boost.
#63
im havin an issue with the dipstick popping out an inch car runs great i had a new head gasket put on recently and i have maybe 2months on my phenolic intake manifold spacer with new gasket..what next?
#66
nope my car ran fine..
u might see if the pcv valve went bad in the intake mani
Do this
Start your engine and pull the vent hose that goes to your intake from the back of the valve cover off the air intake.. Put your finger over the port on the air intake to keep the engine from running bad..if u have a ton of air coming out that hose i would bet money its a cracked piston
Do this
#72
I'm lookin at aftermarket it's the next thing on my mod list I'm already putting 300whp fully bolted with 160,000 miles so of I replace the rods pistons with aftermarket it will be stronger and like new cuz everything else is replaced
#74
#75
hey guys I'm new to this site I. have a 2006 2.0 supercharged ss I'm having a random misfire I took it to 3 mechanics n can't figure out why it's misfiring I replaced spark plugs coil packs n still misfiring I brought it to a thrid mechanic n he said it could be the intake gasket like everyone else is talking bout do he replaced it n still throwing random misfire code any suggestions on what it could be I live in central nj n was wondering if there's a shop that works on cobalts that can scan my computer to see what kind of tune I have on it
