ALERT**Dipstick popping out? Here is solution!
Old 01-25-2013, 02:02 PM
  #76
Pauliejp's Avatar
If your Dip stick is popping out theres a good chance that you have to much blow by and one of your pistons is taking a sh*t. Happened to me until the piston collapsed. You May want to run a compression test. The #4 piston tends to go bad after awhile of running high boost because after 17 psi the fuel rain no longer equal pressure through the whole rail and the 4th injector goes lean.
Old 12-24-2013, 02:50 PM
  #77
Freddy_Lasers57's Avatar
I am very skeptical that this gasket is going to fix the problem for dipstick is popping out. If the gasket is bad pressure would blow from between the mating surfaces
Old 03-24-2017, 09:14 PM
  #78
mundo's Avatar
I've never had my dip stick pop out on any of my LSJ cars. This a common thing?
Old 11-18-2021, 09:05 PM
  #79
Smc252's Avatar
yes, it is happening to me after I replaced intake manifolds. I reused the old gasket, bad idea.
Old 12-15-2021, 03:55 PM
  #80
Smc252's Avatar
Originally Posted by c24na
I bought the new gasket and installed it when i took off my s/c last month. I honestly could not tell the difference between the two, other then the part number. I hope it really did change. I sure couldn't see it
Nate
Same here. My dipstixk still pops out too, what size o-rings are people using to prevent this?
10-21-2015 11:57 PM
Jimmy Beilfuss
10-05-2015 04:18 AM
SlowSaturn
09-28-2015 11:03 AM
metroplex
09-27-2015 07:48 AM
Quick Reply: ALERT**Dipstick popping out? Here is solution!
