The quest for 600whp
Old 11-24-2013, 07:38 PM
  #76
TStone's Avatar
Call comp and tell them what you want out of the car. Alan can do the installl for you
Old 11-24-2013, 08:42 PM
  #77
bmcc2584's Avatar
Originally Posted by 574
I still haven't decided what cams I wanna go with. Custom from comp seems like a pain because I don't know what specs to tell them, and I don't know how to use adjustable cam gears.
As for zzp cams, I don't know if I would want stage 2 or 3 reverse split. I want the car to still be DD friendly.. hmmm
I've got stage 2 and they're still very streetable. Idle is right at around 1k rpms. Sounds pretty much stock. You won't be disappointed if you get them. Car hits hard as hell.
Old 11-25-2013, 07:13 AM
  #78
armcclure's Avatar
With the boost level you're going to run, I'd go with a reverse split.
Ryan's car still runs very smooth on them.
Old 11-25-2013, 09:06 AM
  #79
574
574's Avatar
I have a feeling your gonna be mad again, but I just got a smokin deal on Lars zzp stage 2's
OKAY I'M DONE BUYING STUFF
Old 11-25-2013, 09:13 AM
  #80
kxrida2000's Avatar
Originally Posted by V8THIS
the one i have on it now is cable yes, but the fly by wire gm truck tb is the same mounting flange, i didnt see you had a manifold in the pictures in your garage,
a big part of making power that big is getting the air in, i reccomend going bigger on your tb harmonics and valvetrain are very important too dont get me wrong.
Lol at you
Old 11-25-2013, 09:20 AM
  #81
574
574's Avatar
Well thats no fun!
Old 11-25-2013, 11:33 AM
  #82
armcclure's Avatar
E helps with the "sound"
But understand that if you're running high boost the "sound" doesn't make the most power.
Minor overlap is only beneficial when boost is higher than exh mani pressure.
Once you get to high boost levels, exh manifold pressure is usually 1-1.5X boost pressure (depending on turbo efficiency) and too much overlap will allow reversion.
That's part of the theory behind reverse split cams.
A bigger intake cam lets the air in, and the smaller exh duration with high lift gets the exh out without letting it push pack in.
You should do just fine with those though.
Old 11-25-2013, 11:57 AM
  #83
574
574's Avatar
Awesome. I shell shocked my bank account by buying so much stuff at once though I could't pass Lars stuff up because I was gonna need it eventually and it woulda been stupid to pass up his deals.
Old 11-25-2013, 12:50 PM
  #84
taintedred07's Avatar
Good investment though for sure
Old 11-25-2013, 12:55 PM
  #85
574
574's Avatar
You know it
Old 12-02-2013, 03:04 PM
  #86
574
574's Avatar
Considering selling my 1000s for some FIC's. ..
Old 12-02-2013, 03:14 PM
  #87
InfraRedline's Avatar
I am considering the same. Not sure when yet though.
Old 12-02-2013, 03:38 PM
  #88
armcclure's Avatar
Old 12-02-2013, 03:39 PM
  #89
armcclure's Avatar
At least you know it'd be an easy sale
Old 12-02-2013, 03:47 PM
  #90
slitterell's Avatar
how much are the FIC 1200 running?
Old 12-02-2013, 03:59 PM
  #91
574
574's Avatar
The market is about to be flooded with ID'S when a year ago you couldn't buy used lol
Old 12-02-2013, 04:12 PM
  #92
Most people don't even need the size of the ID's though, and those of us who do may need bigger. I still am a huge fan of Injector Dynamics, just all around, but I like how the FIC's are turning out. It's kind of funny, our platform is finally breaking into the range of needing the "larger injectors". On Evo's and srt's and such, 1000cc's are small to intermediate sized lol. We always have been way behind in making power though. Some of us will at least close the gap a little this year
Old 12-02-2013, 04:24 PM
  #93
574
574's Avatar
I just saw John said he got 1600's.......................... that may be a better option lol
Old 12-02-2013, 04:29 PM
  #94
My friend's evo with Precision 1600's made it 704whp on E85 and had a little bit of injector left. AWD though and different motor of course, but it gives you an idea. Other friends Evo made 743whp on FIC 2150's with tons of injector left. Another friend's STi maxed out his ID1k's and double pump setup at 485whp, but Subaru's are hard pressed to make power, you really have to overbuild them to make the same power as other platforms. He added ID2k's and a makes 532whp now.
1200's will take our platform to over 600whp I believe.
Old 12-02-2013, 04:32 PM
  #95
574
574's Avatar
True, I just know it's better to have too much injector than not enough. I also don't want 2000's because I won't get my use out of them. Well maybe I will but not yet
Old 12-02-2013, 04:46 PM
  #96
Agreed, might as well have extra for the future rather than possibly falling short.
Old 12-02-2013, 04:51 PM
  #97
armcclure's Avatar
The 1200's are the biggest fic can do in a split spray currently. They're used almost exclusively in gtr's, and are the injector Lingenfelter puts in every car.
The 160#ers John got are an off the shelf bosch natural gas injector. They have approximately a 12 or 25* single cone depending on the exact part number. Fic sells the same ones, and they do well. Not as good as a split cone, but much better than the 4-6* spray of the seimens/deka and ID's.
The 1200's I have can handle over 7bar and still function properly. At our stock rail pressure they flow 1320cc.
Old 12-02-2013, 05:04 PM
  #98
574
574's Avatar
So they could potentially flow a lot more with raised pressure?
Old 12-02-2013, 05:17 PM
  #99
armcclure's Avatar
Pressure^2=Flow*2
This is for base pressure. So with a 55psi base you're going to see about 1300cc. Like Taylor said, this could take you well into 600.
What I don't understand is why no one is catching on to an incredibly simple solution to maxing out your rail injectors.
Hint: it's been done on tons of ecotecs. Just not any lsj that I know of. And I would only do it with e85. Scratch that. I AM doing it with e85.
Old 12-03-2013, 02:23 PM
  #100
574
574's Avatar
Interesting...
Quick Reply: The quest for 600whp
