07blackg5 Build Thread. Operation Moneypit
#149
Wait to see how the 90 fits, but i would try to keep the end of the npt side as flush to the inside of the manifold as possible. Just so that air doesnt have to go over a lip to get out. It should make a minimal difference, but every little bit counts. If you already tapped it too deep, you can always grind down the end of the npt side, if you have a grinder and can keep the threads clean.
#150
I can delete the rear o2 sensor altogether, correct? I am stripping this harness as much as possible, and don't care about going back to stock. I'm cat less now with the code shut off, I just want to make sure I can disconnect it and be fine.
I already know the answer, just want to hear it from someone else haha
