Cobalt Parts Interchangeability
Old 02-23-2017, 09:34 AM
  #326
umrdyldo's Avatar
Originally Posted by 08_Slowbalt
So I keep warping my rotors after a few times blasting down these back country roads. I was looking at just putting drilled and slotted rotors on my car but I came across a post on Instagram by @mbray_93 showing he did Mini Cooper rotors and LSJ calipers. Any one heard of this before? I'd love to do some drilled and slotted rotors with LSJ calipers.
What type of rotors are you putting on your car? Stock?
A good set of rotors and pads shouldn't do that. I have not heard of Mini rotors on a cobalt. We have plenty of products out there that should be higher performance. You may have to spend some money though.
Do you have 4 or 5 lug wheels?
Old 02-23-2017, 09:41 AM
  #327
jdbaugh1's Avatar
Pretty sure only the base base models came with 4 lug wheels.
Old 02-23-2017, 10:21 AM
  #328
08_Slowbalt's Avatar
Yeah I'm 4x100 4 lug, same as the Mini Cooper. It seems like a decent upgrade for pretty cheap. I can get drilled and slotted rotors for a Mini for the same price I can get drilled and slotted rotors for a 4 lug cobalt from Rockauto.com and my cost on NAPA SS/SC front calipers is $56. I'm more curious about the size difference between the LSJ caliper and base model caliper. I might order one and just look at it compared to my factory calipers.
And I just keep throwing NAPA rotors on this car and cutting them down all the time lol. Cut them two or three times then just order some new ones.
Old 02-23-2017, 11:31 AM
  #329
jdbaugh1's Avatar
I put these on mine as I also had warped rotors and these have been holding up really well. I put these on mine as I also had warped rotors and these have been holding up really well.
I have a little over a year on them as dailies and autocross in the summer.
I actually have a set of front LSJ calipers I was thinking about putting on in the future so if you need some dimensions pulled I can probably help you out with that.
Old 03-03-2017, 07:22 PM
  #330
Lowcamaro's Avatar
Will a non supercharged block and internals work in a SC car? Like can I take a 2.0 out of an LS or LT and bolt my SC up and go?
Old 03-04-2017, 06:03 PM
  #331
COBALTace's Avatar
Can you install an lsd on getrag f35 5 speed?
Old 03-16-2017, 04:59 PM
  #332
the LS and LT have a 2.2 but the rods and pistons are weaker. I'd suggest just sticking to a LSJ bottom end if you already have a supercharged car.
Old 03-16-2017, 05:01 PM
  #333
the F35 came in the SS cobalts and some of them came with a LSD so I'm sure its absolutely possible to install a LSD. Base model cars came with the F23 and there are a few LSD options there as well.
Old 05-28-2017, 01:17 AM
  #334
Kbrown's Avatar
Can a 07 cobalt LT FIT 07 cobalt ss supercharger???
Old 09-15-2017, 11:50 AM
  #335
lnf pistons in a L61?
Old 09-15-2017, 12:58 PM
  #336
umrdyldo's Avatar
Yes you will need a lot of parts to make it work, but not a real difficult project. There should be multiple threads on here about it.
Old 09-15-2017, 01:00 PM
  #337
jdbaugh1's Avatar
Yes but it doesn't just bolt on. There are a lot of supporting parts required to make it work. Lots and lots of info online about it. The youtube video below should give you a pretty good idea of what it takes.
Old 01-03-2018, 12:25 PM
  #338
so I know LSJ Pistons will work in a L61 but has anyone ever ventured to put say, some cheap LSJ pistons from Rockauto.com in their motor? They have Enginetech pistons for $22 a piece. I know you get what you pay for but its not like I'm trying to do some kind of crazy build.
Old 01-03-2018, 12:29 PM
  #339
jdbaugh1's Avatar
I know LSJ pistons have the same bore diameter but was under the impression they are different because of compression and stroke
Old 01-04-2018, 04:29 PM
  #340
Maybe I should have specified I was building a motor for a turbo. So the 9.5 ratio wouldnt be that bad. I'm pretty sure the GMPP ecotec build book lists LSJ rods and pistons as a upgrade for the L61 motor. I guess I need to go verify that.
Old 01-05-2018, 01:50 PM
  #341
jdbaugh1's Avatar
Yeah as long as the pistons aren't configured differently for the different stroke lengths. I was under the impression that they are. If not I would have definitely considered LSJ pistons because there are more options for them vs. L61. I have some lightly used 2.2 10:1 forged Wiseco pistons I would sell you though I don't think as cheap as what you are looking for.
Old 01-05-2018, 03:21 PM
  #342
Sharkey's Avatar
the different stroke length between the 2.0l and 2.2l would require a shorter connecting rod to run the lsj piston. there is something in the build book about doing this, but it wasnt as straightforward as dumping lsj parts into the l61
Old 01-08-2018, 07:23 PM
  #343
I was under the impression that you could just use the LSJ pistons and rods in the L61 as an upgrade. I have a spare block laying around and I am trying to do a real light build on it as cheaply as possible.
Old 10-16-2020, 06:02 PM
  #344
Cobalt×sc's Avatar
Originally Posted by YellowLT
Here a List of all The SS Parts that fit on the Base LS LT Models
Suspension:
FE 3,5 Shocks
FE 3,5 Struts
FE 3,5 Springs
FE 3,5 Front Sway bar
FE 3,5 Control Arms
Wheel hubs
Strut tower mounts
Rear axle
FE 5 Steering rack
Engine:
Exhaust Manifold
Downpipe
Exhaust
Intake Manifold (Will Physically fit but TB will not bolt up)
#32 Injectors Fit Leak free, Tuning is needed.
Pistons
Rods
Valve Springs
Supercharger and Throttle Body with Intake Manifold (tunning needed)
Drive Belt
Interior:
All of It
Exterior
Front Fascia
Rear Fascia
Rocker Panels
Deck Lid w or w/o Wing
Rims (07 only if you have factory alloys wheels.)
Headlights (SS are slightly tinted. I believe 07 has no orange reflector over DRL)
If you have anything else, I'll be glad to add it.
what about interior wiring? I know the bcm wouldn't work .. but I have one I just need wiring.. so would I be able to use my interior wiring off my 2.4 ss on my lsj build? Not the engine wiring.
Old 03-15-2024, 11:41 AM
  #345
Polly0420's Avatar
Subframe ??
Will the front subframes for an SS interchangeable with the LS
Old 03-16-2024, 06:37 PM
  #346
Rockwell's Avatar
Couple questions might be completely dumb but I'll ask anyway. I have an 07 with the 2.2, and I have a line on a 2.4 direct injection. I would like to put in its place. What would I need for flywheel/clutch to mate them together, and will I be able to take the equinox computer and harness to run the engine, or would I need to adapt the harness and find someone to tune the ecm for the muttchild. 2nd option is take the 2.2 head and put it on the 2.4 will it run with the factory 2.2 tune? Both engines need overhauled I just like the idea of the piston oilers and seems to be the cheapest route to have them. I would like the direct injection as well but don't care for the vvt stuff( could I just put 2.2 cam sprockets on the 2.4 cams.) Ultimately I would like to use the complete 2.4 direct injected engine and eliminate the vvt. Physically it should work. Electronicall??? I don't know
dennis69
10-20-2015 04:49 PM
OrngBalt
09-16-2015 07:45 PM
XStylus
Forced Induction
09-16-2015 06:19 AM
ROADKONE
09-09-2015 02:32 PM
Quick Reply: Cobalt Parts Interchangeability
