coolant temp???
coolant temp???
just wondering if anyone knows whats a good temp for your coolant to be at??? mine usually says 198 is that too high??? cuz some times it gets up to 212... just wondering when i need to start wonderin when its getting to high
https://www.cobaltss.net/forums/show...t=coolant+temp
Read that thread...should answer any questions you have.
Originally Posted by betterthanbad
For all you Canadians.....................83-84 degrees is normal operating temp and all I've ever seen even driving WOT.
Originally Posted by D4u2s0t
i think over 230 is too high... welcome dude... where-a-bouts in jersy you from?
Originally Posted by tiny
i just got mine filled, and they put in the green coolant instead
i was pissed, so i went and bought a bottle or Water Wetter
Originally Posted by Tomtwtwtw
There's no difference in performance between the green and the red / orange / whatever color they put it. You just can't mix them. As long as they flushed it first, then re-filled with green, you're good to go. I had my Pontiac flushed and filled with green after my radiator, heater core, and water pump all had to be replaced in a 1-year span. No problems after that, except the heater core going again, but that was due to a bad install from the shop.
then why do they put in the Dex-Cool?
i have had mine get up to about 230 max when i was sitting idle in the staging lanes at the dragway but as soon as i went down the track it droped back to around 190 where it usually stays
really?
Originally Posted by tallyphotog
^^^ Last time I bought Dex-cool, it was ORANGE! I hover in the low 190s while driving in the city.
z28addiction
09-28-2015 12:03 AM
