oil pan replacement
undo the two bolts visible in the first picture, remove the a/c lower bolt, like Maven said in 2009, and remove the front motor mount. Two passenger side bolts are a pita to get off use a wobble socket or an open end wrench over and over and over, and two are masked by the pan, and need an extension.
torque specs are? hmm 18 ft lbs iirc and the tightening pattern is radial from the center out.
count the bolts to make sure you have removed enough.
lsj pans hold 6.5 litres the rest hold 5 litres pretty much
DANRICKARD
10-01-2015 12:08 AM
importkiller
09-30-2015 07:18 PM
