Gmpp clutch for the 2.2?
Just recently supercharged the 2.2 and its slipping. Just wondering if anyone knew if the gmpp clutch will work with my 2.2?
I'm a little confused actually. I was looking at the ZZP 2.2/2.4 9.5" clutch as well. The description says it will work for a f23 or f35 trans. Isn't lnf the f35? If it is how can the lnf (f35 trans) and the lsj be the same? If ZZP's 9.5" clutch works for both does that mean that all clutches are interchangeable between the two transmissions (f23 & f35)?
But if I'm not mistaken, that is a custom clutch kit, and is compatible with both transmissions.
Has anyone heard any good things about the ZZP 2.2/2.4 9.5" clutch? Or does anyone recommend a certain brand? I'm trying to research the best clutch for my application (supercharged 2.2 w/3.1 pulley and f23 trans) and it seems that everyone's post has a different opinion on all the different clutches. Thanks in advance for the replies.
